Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Reload Thread: Problems with my 3.5 Farad Capacitor
  1. #16
    Chriszle's Avatar
    Chriszle is online now CarAudio.com Elite
    Jan 2011
    SD
    1,504
    7 Post(s)
    Re: Problems with my 3.5 Farad Capacitor
    Quote Originally Posted by Bettr n' Revrse View Post
    Fix ground, ditch cap, Big 3, And then add a second batt if it still doesnt fix the problem...
    x2-I highly doubt you will need a second battery with that little power, once you fix the other problems.
  2. #17
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,860
    72 Post(s)
    Quote Originally Posted by Chriszle View Post
    Yep yep... Thenn when you get that done you can upgrade equipment!
    Western Rep.
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
    -Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
    -Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
  3. #18
    focused313's Avatar
    focused313 is offline Learning With Every Post
    Mar 2004
    Michigan
    245
    did I just see speaker wire being used for a ground? ehhhh
    Had JL 12w3's...replaced with Type R's...and couldn't be happier
    God Is Love.
    Don't , I'm Just Here To Learn.
  4. #19
    Mar 2011
    St. Pete, Fl
    96
    If the lights dimming is your issue why not install the cap on your lights instead of your F&*KED up install. It would do more good than on your amplifier to solve your problem. Post like this are the reasons that you should PAY someone who knows WTF is going on to do the job.
    Quality is derived from experience and time, not price.
  5. #20
    dags_07's Avatar
    dags_07 is offline Junior Member
    May 2011
    Weston, FL
    Quote Originally Posted by BASSMEKANIK89 View Post
    -.- I said that I ordered the 4 gauge cable to install it. . . I am not blasting my system with that speaker wire I am that dumb. . .
  6. #21
    dags_07's Avatar
    May 2011
    Weston, FL
    Quote Originally Posted by focused313 View Post
    Yes I know. . . it is !@#$% up, is because the 4 gauge that came in the kit was to short, I ordered another one right away, it should come on monday or tuesday.
  7. #22
    drboyd's Avatar
    drboyd is offline Junior Member
    Apr 2011
    SW USA
    Ouch!!
    Personally, I wouldn't run it with the speaker wire ground; you're standing a decent chance of igniting something expensive. In fact, you might find that the capacitor issue will go away when you use the correct ground wire. Depends on how the capacitor circuit thingy is designed.
    Quote Originally Posted by MisterDeadeye View Post
    I hate to say it, but you are indeed that dumb. You're dumb for even considering using speaker wire for a ground AT ALL. But it's okay, you'll eventually figure out car audio isn't for you.
  8. #23
    Mar 2011
    St. Pete, Fl
    96
    The reason that the ground wire didn't reach is you installed the amp in the wrong location. The grounding point should NEVER EVER EVER EVER EVER EVER be mor than 15-18" from your amplifier. You probably didn't even order real copper wire. Im guessing best "value" like a CCA wire... I hope you have marshmellows and some oscar meyer's in your emergency kit.
  9. #24
    audioholic's Avatar
    audioholic is offline Moderator
    Aug 2003
    Parts Unknown
    23,749
    36 Post(s)
    Get the ground wire fixed, and then come back and let us know if the problem persists. Its hard enough to diagnose a problem over the internet, but virtually impossible when there are other known problems in the system, such as a grossly undersized ground wire.
    For the length of wire that you should require to simply ground your amplifier, next time just buy wire locally. You should be talking about like 10 bucks worth of wire, even at full retail prices.
    No speaker, in the history of speakers, has ever been blown by too little power. Ever. I don't care what your friend told you, he's a dirty liar.
  10. #25
    Nov 2010
    Brandon , FL
    31
    4,640
    5 Post(s)
    what you guys never thought of here is if he is dimmimg using a speaker wire for ground , imagine how hard he will dim when he actually starts pulling major current with the correct wire. def ditch the cap , big 3 and you should be ok.
  11. #26
    brettley's Avatar
    brettley is offline Member
    Feb 2011
    Minnesota
    59
    DO NOT RUN WHAT YOU HAVE, replace your ground wire, ditch the cap, get a small power cell battery (stinger or kinetik). Do your big 3
    2 - Kicker L7 12"
    Pioneer AVH-3400BT
    2 - Kenwood KAC-9104D
    Playstation 2
    KnuKonceptz big 3 1/0 gauge OFC
    rockford and knukonceptz wire
    6 cube feet total box space ported
    infinity kappa in the deck and doors
  12. #27
    Phoenix Risen's Avatar
    Phoenix Risen is online now OG.... Original Ginger
    Jun 2010
    Dayton/Springfield, Ohio
    3,964
    27 Post(s)
    the poor ground is the reason that he is getting voltage drops.
    500 watts should never make lights dim. unless the alt and batt in the car are dead.
    R.I.P. 2008 Hyundai Tiburon GS
    2005 Subaru Baja turbo, build in planing stages.
  13. #28
    jco1385's Avatar
    jco1385 is online now expert jcologist
    Sep 2007
    Mobile, AL
    18,074
    2 Post(s)
    i said all this 5 days ago
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
  14. #29
    dags_07's Avatar
    May 2011
    Weston, FL
    -.- if you are going to troll I can give you some change to buy you a better life. . . I did order real copper wire, and the ground is not even 2" away from the amp so. . . -.-
  15. #30
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,074
    2 Post(s)
    if you pull the cap, then you'll have a ground wire to use, right?
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
Tags for this Thread
