1994 Thunderbird
JVC KD-AV7010
Alpine 6x9 3-ways
Pioneer 6x8 3-ways (rear)
JVC CH-X1500 12-disc MP3 Changer
Alpine Type X 12" 2 cubes @ 30hz
MTX 404 runs the inside
MTX 1501d runs the X
Optima G75/25 RT up front
2x Optima G31 YT in the trunk
200a EA HO Alt (1/0 Big 3)
ALL MY WIRE IS WELDING CABLE
DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
OFFICIAL FEEDBACK THREAD
yea, thats about the only thing that ***** about hondas... weak *** alts
you should be ok with a small second batt... as long as you wire everything properly. a kinetic 600 in the back would def help alot... i dont see you getting much headlight dimming with that installed, but, what 800 watt amp will you be installing?
NEW TO CAR AUDIO? READ THIS FIRST... http://www.caraudio.com/forums/general-discussion/532425-new-car-audio-read-first.html
the loudest montero sport around
head unit: toshiba thrive 10.1" android tablet/ Kenwood KVT-516
front stage: each door: 1 8' RF p1 (midbass), midrange: 2 cadence cwm6.5's, 1 memphis pr 6.5 coax (kickplate), 1 cadence 4' coax (a-pillars)
subs: 4 AQ HDC3 18'S, walled in a clamshell
amps: subs: AB 500.1, looking for a second; midrange and midbass: 2 AP 1000.4
no actually it was always in there lol, and it was also in the post right before you asked. its 4 gauge
1994 Thunderbird
JVC KD-AV7010
Alpine 6x9 3-ways
i would upgrade the big 3 to 0 gauge if your going to run a second batt... might be a lil bit of overkill, but the way i think about it, is the less restricted your electrical is, the better everything else will work
okay sounds good, I think I will upgrade the 3 first and see how things go and if I still have dimming and issues I'll just **** it up and get the battery and all that $100 aint as bad as I thought it would be for the battery itself + wires and all that it's still cheaper than a new alternator
75 amps is enough to run just about any 1000 watt system. I do not think you need a second battery, but if you want one it will not hurt anything.
might as well load test the alt while you're doin it to make sure it's solid.
1994 Thunderbird
JVC KD-AV7010
Alpine 6x9 3-ways
what size fuse should be on the wire going from the alternator to the battery pos?
1994 Thunderbird
JVC KD-AV7010
Alpine 6x9 3-ways
yeah I've noticed some people do some people don't do the fuse
if your running 0 gauge, it should be matched to your alt output, but higher to protect against spikes... i would say a 150 would prolly work fine, with one batt...
and the fuse really is kinda optional... i've never seen an alt spike enough to **** up a batt... or a batt pull enough to **** up an alt (when it is ran properly, mind you... any idiot can **** up an alt in 20 minutes, not knowing what they're doing) .. but i do it just for a lil bit of overkill i guess
1994 Thunderbird
JVC KD-AV7010
Alpine 6x9 3-ways
Knukonceptz product detail for IN-LINE WATERPROOF ANL FUSE HOLDER W/ FUSE
this one here is all the same price up to 300amp so I'm guessing it doesn't hurt to run a higher one?
Bookmarks
