Results 1 to 8 of 8
Reload Thread: Wiring Issues, Please Help
    jmann83's Avatar
    jmann83 is offline Junior Member
    Apr 2011
    Pulaski, VA
    Okay so bought a head unit about 10-12 months ago and installed it, and everything worked wonderfully. Now for about the past 3 months or so my stereo works intermittently it cuts on about 1/4 of the time i start my car or some times at random while driving then just randomly cuts off. When I try to eject a CD or hit the display button it will preform either one of those functions then goes off. I just had time to get in there and screw around with it. I have checked all my connections to make sure nothing was grounding out, I also check and re routed my grounding to make sure that wasn't an issue. I have checked my fuses to make sure nothing was only partially plugged in or blown. I'm kind of at a loss for what to do now. Any suggestions would be greatly appreciated. Thanks
    Apr 2011
    Sheboygan. WI
    107
    Re: Wiring Issues, Please Help
    Not enough power is being sent to the head unit. Or a lose wire inside the unit. Or its malfunctioning.
    CivicGti's Avatar
    CivicGti is offline CarAudio.com Elite
    Dec 2010
    Texas
    684
    1 Post(s)
    if it has a detachable face make sure the faceplate is making a good connection to the unit, use alcohol swaps to clean the connection pins
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    Buck is a Supporting Vendor of the forum!
    May 2008
    Nashville
    17,509
    150 Post(s)
    Quote Originally Posted by CivicGti View Post
    Radios usually play without the faceplate though.
    Bought from: kmanian(x2), KyleBetchtold, Rio, 05_ZX636, SoCalNoob, dave_damage
    Traded with: cj407, twistedchild420
    Sold to: jadon087, dvldogyut, 95saturn, many box designs...
    Click for High Output Enclosures Email (formerly Buck Box Designs)
    I do sealed, ported, t-line (consistent width), 4th and 6th order bandpasses.
    I answer any audio questions sent to my email for free.
    Alpine - CT - ASE (local) - Batcap - C&D Tech - DC - eD - Excessive Amperage - Rainbow
    In Nashville? Me too! Pm me and come hangout!
    CivicGti's Avatar
    Dec 2010
    Texas
    684
    1 Post(s)
    good point I didn't think about the fact that he said it cut completely off, I had a really similar issue once upon a time and it was a grounding issue, you said you relocated your ground wire, when you picked your grounds did you meter the voltage from the constant to the ground you used... what kind of vehicle is, some has weird grounds
    Buck's Avatar
    May 2008
    Nashville
    17,509
    150 Post(s)
    It simply might be some wires aren't connect well in the back. It can happen.
    jmann83's Avatar
    Apr 2011
    Pulaski, VA
    Its a 99' Pontiac TransAM. I ran a temp wire from the head unit through the firewall of my car and connected it the the chassis of the car just to make sure i had a solid ground that something else was hooked to. When I ran the temp ground it still had the issue. I beginning to think its just the head unit its self.
    CivicGti's Avatar
    Dec 2010
    Texas
    684
    1 Post(s)
    starting to sound like it but
Tags for this Thread
