Results 1 to 15 of 15
Reload Thread: Amp Tuning??
    yanksfan407's Avatar
    yanksfan407 is offline Junior Member
    Apr 2011
    Massapequa, NY
    Amp Tuning??
    I need to know what to tune my amp to. I have an Alpine MRP 500 at 2ohms by 500 Watts RMS powering an Alpine Type R Dual 4 Ohm Voice Coil. I have two amps powering two subs. One amp per sub. Someone help please. I dont know what to tune my knobs to on the amp. Do I install them and adjust it as I like it or is there set specs it should be at?
    Phoenix Risen's Avatar
    Phoenix Risen is offline OG.... Original Ginger
    Jun 2010
    Dayton/Springfield, Ohio
    4,064
    350 Post(s)
    Re: Amp Tuning??
    the gain/input should be matched to your preout voltage, the lpf should be set 80-100hz depending on your front stage, and the sub sonic (if it has one) should be off for a sealed enclosure and around 10hz under tuning on ported boxes.
    you can also set the gain with a DMM which is much more accurate.
    R.I.P. 2008 Hyundai Tiburon GS
    2005 Subaru Baja turbo, build in planing stages.
    rumdada's Avatar
    rumdada is offline Senior VIP Member
    Mar 2011
    Pittsburgh
    463
    9 Post(s)
    Re: Amp Tuning??
    make sure you tune them both at the same frequency or you'll get nasty sounding bass but you should aim for 80-100hz
    Sold to : cm2658
    Frnt-Kenwood Comp KFC-P709PS
    Rear-Kicker Kicker DS6930
    Amp-Meance 3000.1
    2 10'RD Sonace's
    Custom Box Tuned to 35hz
    Jun 2010
    4,064
    350 Post(s)
    Re: Amp Tuning??
    also make sure you have the bass boost off. if you crank it up you wont like the results.
    Apr 2011
    Massapequa, NY
    Re: Amp Tuning??
    Bass boost on the stereo deck? Just confimring
    Apr 2011
    Massapequa, NY
    Re: Amp Tuning??
    Or bass equalizer on the amp? What do I set this to?
    Jun 2010
    4,064
    350 Post(s)
    Re: Amp Tuning??
    bass boost on the amp. if it has it. also keep the bass boost on the deck off as well.
    Apr 2011
    Massapequa, NY
    Re: Amp Tuning??
    ok thanks now my stereo deck says pre amp voltage is 2 volts, what do i set the gain to? I have a choice of MIN-, -, -, NOM-, 0.5V-, -, MAX-
    ---------- Post added at 12:43 PM ---------- Previous post was at 12:43 PM ----------
    And the bass equalizer is from 0-12 dB, I choose 0?
    ---------- Post added at 12:44 PM ---------- Previous post was at 12:43 PM ----------
    And what do you mean by front filter?
  9. #9
    Apr 2011
    Sheboygan. WI
    107
    Re: Amp Tuning??
    I set my head unit on -10db
  10. #10
    whitedragon551's Avatar
    whitedragon551 is online now Moderator
    Mar 2009
    IL
    13,601
    42 Post(s)
    1434 Post(s)
    Re: Amp Tuning??
    Quote Originally Posted by DeathByWaffle View Post
    Then its wrong. It needs to be at 0 or flat and so does the amp.
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  11. #11
    SPL Blazer's Avatar
    SPL Blazer is offline SPL Event Promoter
    Mar 2008
    Peabody, Massachusetts, United States
    2,580
    15 Post(s)
    Re: Amp Tuning??
    Bass on the headunit should be at 0, bass boost on the amp should always be off. The input levels on the amp are going to be somewhere like 3/4 of the way up since it's only a 2 volt headunit. Using a DMM on both amps would work best to make sure you have them at the same level. If each sub is in it's own sealed chamber it wouldn't be as big of a deal, but when they share the same chamber you need them both set exactly the same.
    Walled Astro, 4 DC Audio 18" XL's _____________________www.NewEnglandSPL.com
    1 Hifonics Sampson - 157.7 so far
    Bought from: CRXBMPN, SPLTucson, f150john, LoudMOFO Sold To: Chris Team ACT, Big Rea$e
  12. #12
    Mar 2009
    IL
    13,601
    42 Post(s)
    1434 Post(s)
    Re: Amp Tuning??
    Quote Originally Posted by yanksfan407 View Post
    1. What amps and what subs?
    2. Yes the bass EQ should be at 0, bass boost at 0, and the HU bass setting at 0.
    CA.com FAQ's
    Forum Rules
  13. #13
    SPL Blazer's Avatar
    Mar 2008
    2,580
    15 Post(s)
    Re: Amp Tuning??
    Quote Originally Posted by whitedragon551 View Post
    It's in the first post, assuming you would have read that
  14. #14
    Mar 2009
    IL
    13,601
    42 Post(s)
    1434 Post(s)
    Re: Amp Tuning??
    OP you need to get a DMM and follow this equation. Use a 50Hz 0DB test tone.
    Voltage = SQRT(Power*Resistance)
    Voltage = SQRT (500*2)
    Voltage = SQRT(1000)
    Voltage = 31.62V
    Each amp should read as close to that as possible for the voltage at the speaker wire inputs.
    CA.com FAQ's
    Forum Rules
  15. #15
    Apr 2011
    Sheboygan. WI
    107
    Re: Amp Tuning??
    Lol. I can't sit in a car where im sitting like 3 feet away from the subs listening for distortion. Hurts my ears. And like what do you set the freq. to? Cause I always set it to right before I hear like a hollow sound from the box. Idk. haha
