4-Ch. Selectable Amp, 2 speakers, and Bridged Sub. Wiring Question..
Hello, Kind of a noob to this wiring setup and I need up help with the proper configuration for wiring this set up...
This is what I'm trying to hook up:
Aftermarket stereo with 2 preamp outputs
A 4-channel amplifier with selectable 2-3-4 channel selection....... I am assuming it is 3 correct?
1 set of component speakers
1 subwoofer
I've got everything installed... I really just need help with the proper way to hook up my stereo to my amplifier.
1) On my amplifier it will be a 3-channel set-up correct? (1 set of speakers and a bridged sub)
2) With 2 preamp outputs on my stereo, will this be enough for the speakers and sub?
Hope this is isn't too vague lol
Re: 4-Ch. Selectable Amp, 2 speakers, and Bridged Sub. Wiring Question..
Basically what I am asking is....
I would need two preamp outputs correct?
So if I got an equalizer with two RCA outputs that would be sufficient?
Yes, you have it in 3 channel mode, you just need one set of RCA for the front components into the amp and one set for the back subwoofer
