Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Reload Thread: did big 3 but didnt fix problem
  1. #16
    ctalley44's Avatar
    ctalley44 is offline Junior Member
    Oct 2010
    louisville, ky
    17
    Re: did big 3 but didnt fix problem
    gonna pull the system out and check all connections to be sure but dont think this is gonna be the problem. gonna double check grounds and cap wiring
  2. #17
    daboyfrumdabx's Avatar
    daboyfrumdabx is offline CarAudio.com Elite
    Dec 2009
    Pleasant Mt., PA
    28
    1,199
    39 Post(s)
    Quote Originally Posted by ctalley44 View Post
    Quote Originally Posted by disturbed471985 View Post
    ^^^ This. Sounds like you have a wiring issue. BTW that 2400 is the same as that deka so you did not upgrade you just side stepped.
    If you feel u need to seperate batts then get a isolater. It want fix your problem but do what ya do. P.S kick that cap in the water.
    Just in case you missed that.
    *Sundown Z15 *SAX-1200D *CDT HD-61A *SAX-100.4 *Pioneer DEH-80PRS *KnuKonceptz *XS Power D3400 *270A Mechman
    Sold to: blackbonnie, TheOneJordan, resko1, kr15, Zichardruniga, IBmikexxx, plugitin
    Bought from: Gruszka530, theMessenjah44, ltr450racer690, Dpc69ss, 97maxima(Here and ROE), Pillow(CACO), pro-rabbit, woofercooker, Twisted_0912
  3. #18
    tpmeredith's Avatar
    tpmeredith is offline Senior VIP Member
    Aug 2010
    Murfreesboro, TN
    26
    415
    I agree with ditching the cap.. Has to be connections or alt with that kind've power IMO
    I'm running a 2500rms memphis amp and a 4chan memphis amp on stock battery/alt with big 3 done and on full tilt it never drops below 12v
    Still a little low for me though I'm gonna up battery and alt eventually
    Granted I'll say the stock interceptor battery/at is pretty big but not as big as yours, I think my alt is 140a
    Refs: Errollito, dacheatham, pro-rabbit, splaudio, davidtemple, Bad4health
    03 Crown Vic Police Interceptor
    Amps: Memphis Mojo 2500 RMS Mono Amp, Memphis M-Class 50x4 amp
    Sub: Memphis Mojo Rebuilt by SPLAudio handling 2500RMS
    Box built by Pro-Rabbit
    Headunit: Pioneer P3300BT
    Speakers: Memphis M-Class 5x7's front/back, soon to be MA Rk6's
    Big 3 done, Deka 8a31 in the back and C&D in the front, voltage never below 14v
  4. #19
    ctalley44's Avatar
    Oct 2010
    louisville, ky
    17
    thanks for the input tpmeredith ill bypass the cap and get back to you all and see what conclusions i have
  5. #20
    ctalley44's Avatar
    Oct 2010
    louisville, ky
    17
    looks like its the alternator after all. something to do with the voltage regulator inside it. Thats its not responding to the drop and demand for power. the tech says its common with these rebuilt beefed up alternators. gonna get it rebuilt , cheapest way to fix it. Everything else looks fine though all other wires are ok. its hodling a t 14.5 without a load but under load the alternator is f**Ed up and wont respond in time thats why it kicks off the subs and amps and everything else.
  6. #21
    tpmeredith's Avatar
    Aug 2010
    Murfreesboro, TN
    26
    415
    What brand alt is it? Honestly it might be more worth your money to look into a DC Power or mechman alt, you could rebuild it and it could just start going out again, a lot of alts just arent meant to take extended loads
  7. #22
    tpmeredith's Avatar
    Aug 2010
    Murfreesboro, TN
    26
    415
  8. #23
    ctalley44's Avatar
    Oct 2010
    louisville, ky
    17
    hi-amps alternators, a rebuilt NIPPONDENSO. supposed to output 200 amps .but like i said somethings wrong with it and aint letting the alternator get the signal that batteries need juice
  9. #24
    tpmeredith's Avatar
    Aug 2010
    Murfreesboro, TN
    26
    415
    Ya I mean I'm no mechanic or anything, sounds like an offbrand rewind to me, seems if you get it rebuilt/rewound it could just happen again, short of getting a well built one from the get-go
  10. #25
    matt.u's Avatar
    matt.u is offline Member
    Feb 2009
    ohio
    28
    60
    go to excessiveamperage.com and see how much nate will charge you for a 200 or more amp alternator thats where i got my 220 amp and id was fine on 2 aq2200d's @.5 each
    1995 dodge ram 1500 5.9L 360
    H.U. pioneer DEH-P7200HD
    subs-AQ HDC318'S D2
    AMPS- 2 x AQ2200D, AQ4X90
    Selenium 4 x 6W4P MIDS, 16 x ONKYO tweets
    stock alt
    knukonceptz 1/0
    stock battery up front, 2 x Deka 9a31
  11. #26
    Vossy's Avatar
    Vossy is offline CarAudio.com Elite
    May 2010
    St. Cloud MN
    1,509
    6 Post(s)
    I figured it was a regulator problem ;d
    Too bad I didn't read it till now
    2 Sundown Z 12s
    2 AQ 2200s strapped @ 1
    Infinity 6030cs on a JBL GTO 75.4
    in a BMW e46
    Youtube: www.youtube.com/diablo2369
Tags for this Thread
