Results 1 to 5 of 5
Reload Thread: Deep cycle marine battery
    Pataforce8's Avatar
    Pataforce8 is offline Senior VIP Member
    Feb 2011
    Amarillo, Tx
    211
    4 Post(s)
    Would it be okay to install a deep cycle marine battery in conjunction with my current battery?
    In a car period? By itself?
    Power is nothing without control.
    Feedback:
    http://www.caraudio.com/forums/buyer-seller-feedback/507941-pataforce8s-feedback-thread.html
    thegreatestpenn's Avatar
    thegreatestpenn is offline lazy genius
    Nov 2007
    columbus
    9,276
    32 Post(s)
    Re: Deep cycle marine battery
    since the resting voltage will probably be different the batts will pull off each other when the car is off shortening their life. it won't be so bad if u drive the car everyday. Also they will have different discharge rates and that will effect how much juice actually reaches your system when it needs it. Won't work as well as a good agm battery but it'll do something
    http://www.caraudio.com/forums/buyer-seller-feedback/401249-thegreatestpenn-feedback-thread.html
    2k2 honda civic
    summer build
    audison sr4 on focal polyglass 165vb components active
    soundstream rubi1.2500d on dc lvl4 xl 18
    pioneer deh-80prs
    Pataforce8's Avatar
    Feb 2011
    Amarillo, Tx
    211
    4 Post(s)
    Would it be better to replace my existing battery with a deep cycle?
    Feedback:
    DukeNut's Avatar
    DukeNut is offline Senior VIP Member
    Nov 2008
    Ohio
    313
    20 Post(s)
    Quote Originally Posted by Pataforce8 View Post
    No you don't want to do that. Deep cycle batteries are made for extreme discharge and then recharge, not for quick high bursts of power needed for engine cranking like your starting battery is made for. do as penn said above, use an agm.
    Refs:
    jshak07, photocrazy8, DARKHART, dadon, enzowho
    Pataforce8's Avatar
    Feb 2011
    Amarillo, Tx
    211
    4 Post(s)
    Quote Originally Posted by DukeNut View Post
    Alright thanks. I was only wondering because where I work I can get a discount on some deep cycle marines. But I'll just use an agm.
    Feedback:
