Results 1 to 14 of 14
Reload Thread: Wiring 2nd Batt with 2 Amps?
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    Icon32 Wiring 2nd Batt with 2 Amps?
    Ok Guys I have some questions and need advice on the best way to do this... I will probably be adding a second battery to my new vehicle to keep up with the new setup (whatever thats gunna be)... Here is the ways I was thinkin-
    Ignore the ground wire from the front batt to the rear idk why I put that lol
    The power wire from the front to the rear would be my current Knu 1/0 CCA, the amp wires would be the correct size wire with the right fuses (fuse holders are the cyan color), and the ground from the rear batt would probably be KNU OFC 1/0...
    Or there is this way-
    Same thing but one fused KNU OFC 1/0 length off that batt to my unfused distro (purple) that splits to the amps... the ground wires going to there own ground (could also do that with the first setup if its better to ground seperatly?)
    Now questions-
    • Do I need a battery isolator?
    • If so where does it go and what brand?
    • I was looking in to XS batterys does anyone use them?
    • What size would I need? (I was thinking something that was small enough I could move up front if the old one went then get another one for the back)
    Sorry for the long post guys let me know if you have any question...
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Kenwood DNX-692HD_____________ -Head Unit: Eclipse CD7100
    -Sub Stage: Focal KX40 16"_________________ -Sub Stage: Looking
    -Mids/Highs: Focal KRX & PHD AF____________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: Mosconi AS200.4_________________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: Mosconi AS200.4_________________ -Mid Amp: ^^^
    Apr 2009
    dallas tx
    6,930
    55 Post(s)
    Re: Wiring 2nd Batt with 2 Amps?
    do the first diagram. thats how i have always had better success. then ur getting power STRAIGHT from the battery and ur ground is right off the battery. better overall
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    Quote Originally Posted by basscort2009 View Post
    Do I realy need to fuse again in between the rear battery and both my amps?
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    Bump
    ctmaudi's Avatar
    ctmaudi is offline Senior VIP Member
    Sep 2010
    Akron, OH
    374
    5 Post(s)
    Im about to do,
    Possitives, front battery -> fuse holder -> rear fuse holder -> battery -> fused distro block -> split to both amps
    Negatives, rear battery to ground in back -> battery to both amps grounds
    Bought From : BumpinKota (PA P2250D), mmouse57 (wire), Massiveaudiocw (2xSA10s), Slayerx (DSC480, GM-5400t), Outsideshot23 (wire), cdimic25 (HC600), Pro-Rabbit (box)
    Sold To : Spooney (PA P2250D), nd_6037 (GM-5400T), Heeltoeclutch (distro/RCAs), BlactimusCrime (Kenwood HU)
    Other Refs : EOCF.com itrader (cecil), heatware (cecil), ebay (ctmaudirs6)
    2007 Altima 2.5S Sedan - Kenwood KDC-X794 - Crescendo CCX65 - Onyx-480 - AA Havoc 12 D2 - Onyx 1500D - 2.25 net @ 31Hz
    Stock 110amp alt - stock battery - 1/0 kicker hyperflex back to Kinetik HC600 - 1/0 Knu Kolossus Big 3
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    I realy dont see the rear fuse before the rear batt to be usefull... I would rather not spend the extra 35/40 bucks getting one when there is already one on that wire cuz if it shorts it only is gunna take one
    ctmaudi's Avatar
    Sep 2010
    Akron, OH
    374
    5 Post(s)
    Quote Originally Posted by Bettr n' Revrse View Post
    I was told on here to get another fuse before the rear battery. The knukonceptz one is $20 with fuse.
    In the diagrams above you have 3 in the first one, and 2 in the second. Just use the two between the batteries, and get a fused distro block to go after it, or put the third fuse holder by the distro.
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    Quote Originally Posted by ctmaudi View Post
    I didnt wanna get a forth thou lol... I guess Ill just have to see what I can get a fused distro for... I already have one but its unfused
  9. #9
    ctmaudi's Avatar
    Sep 2010
    Akron, OH
    374
    5 Post(s)
    $15 with fuses,
    2 Way Distribution System
  10. #10
    ultimate157's Avatar
    ultimate157 is offline Engineering Student
    Mar 2006
    Worcester, ma
    7,249
    Lol wut. You need 2 fuses on a line connecting 2 batteries. One for each source. If your power wire shorts with only one fuse, the fuse will blow on say the front battery, but the rear battery is still shorted.
    1/0 front to rear on both + and -. 2 Fuses on positive. Connect amps to rear batt, fuse if you like (further the runs amp to batt, the better it is to have it fused). Done.
    2003 Volkswagen Jetta GLI VR6
    Source: Pioneer 880 PRS *Active
    Tweeters: Soon to be Hat Imagine
    Midrange: Soon to be Hat Imagine
    Sub: 15" SSA Icon
    Box: 2.5^3 Sealed
    Amp: Soundstream Tarantula 2kW
    Feedback: http://www.caraudio.com/forum/showthread.php?t=278169
  11. #11
    mossberg385t's Avatar
    mossberg385t is offline Love Train
    May 2009
    Sarasota, FL
    2,291
    4 Post(s)
    I thought I had a better picture, but you can see how I have one of the terminals on the right side of the pic
    Quote Originally Posted by CarAudio.com Admin View Post
    Please send your tithes of 10% to my paypal. Thou shall worship thy goob.
    IA 40.1, Nakamichi PA350, Arc audio 6.5s 2 way active (1986 Alphasonik x-over) Audio Control three.1, Kenwood KDC-X592, TREO SSX based 18: 8 layer flat wound copper coil w/ dual SS former, 3 medium nomex spiders built by SPLaudio and repaired by myself and Harshaw for optimal sexiness and performance.
    team Dbeez MECA as3 db3
    ☞2218☜ βθπ βν
  12. #12
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    Think I get what your saying
  13. #13
    theMessenjah44's Avatar
    theMessenjah44 is offline CarAudio.com Elite
    Apr 2009
    Central IL
    1,380
    4 Post(s)
    First one...and if you can do it, run your ground from front battery to back...more dependable than a chassis or frame ground
    Bought from: jamesw, dave_damage, ampjunkielikeme, JuicyJeff
    Sold to: DaBeholder, ampjunkielikeme, ax600, shackel. Worked with Rio
    Team Edge Customs
    Last year: '05 Ford Escape - Alpine 7995 - AllTsunami 1/0 - C&D batt 15" IA Warden (2) Audiopipe AQX-3500.1's at 1/4 ohm 151.3 outlaw
    This year: '92 Mazda 323 - C&D batt Batcap 4k, (6) Powerbass 15's (250rms each) (1) Audiopipe AQX-3500.1's at 1.3 ohm 152 outlaw
    Currently rebuilding Mazda with (4) American Bass HD 15's in a wall, 157?
  14. #14
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    Alright... so either the distro or wiring of the batt would be ok? and which would be better to run my grounds?
