Results 1 to 2 of 2
Reload Thread: Help on wiring ohms on amp
    Jan 2004
    Oc,Ca
    30
    74
    Guys i need help what happens if u you wire an impedence lower than wat is stable for instance i got 2 type r's 4+4 dvc b4 i thought i could get 2ohms out of them but then i read stuff and it said either 1ohm or 4ohm which ***** cuz i think going 4 would be safer for my amp but i wont get to give them enough power. At 2ohms it wouldve been 450rms but now its gonna go down to 300rms or lower i guess at 4 ohms what should i do btw its on a ca1200 profile amp
    EzekialPhoenix's Avatar
    EzekialPhoenix is offline Senior VIP Member
    Dec 2003
    Minneapolis, MN
    227
    Re: Help on wiring ohms on amp
    Wire it at 4 ohms and bridge it at the amp.
  1. 1000+ Watt Amplifiers
    By Gauntlet in forum Amplifiers
    Last Post: 04-16-2006, 01:07 AM
  2. Wiring speakers to amp and headunit??
    By llknowlesll in forum Wiring, Electrical and Installation Help
    Last Post: 12-30-2003, 10:23 AM
  3. strangest wiring problem ever, PLEASE HELP!!! (thanks!)
    By dragonplayboy in forum Wiring, Electrical and Installation Help
    Last Post: 12-21-2003, 04:51 PM
  4. 1000+ Watt amplifiers
    Last Post: 12-13-2003, 11:36 PM
