Results 1 to 5 of 5
Reload Thread: 0 ga Ring Terminals - Crimp vs Screw in
    bobo244's Avatar
    bobo244 is offline CarAudio.com Elite
    Dec 2003
    Miami Florida
    856
    What is the difference between a crimp style ring terminal and a screw in terminal in terms or performance and ease of use??
    For example between these two ring terminals...
    Crimp
    - http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEBWA:IT
    SCrew in
    Is it very hard to crimp 0 gauge.
    If it matters i am running 2500 watts total.
    THANKS
    indosia's Avatar
    indosia is offline CarAudio.com Elite
    May 2002
    hayward, ca
    593
    Re: 0 ga Ring Terminals - Crimp vs Screw in
    It doesnt really matter.
    You can crimp them with a sledge hammer .
    The screw down ones are nice cause you can reuse them and you don't need a sledge hammmer, prolly just an allen wrench. You could get a battery post clamp that has 0awg connection, then you wouldnt need a ring terminal. Well you would still need one for ground.
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    i prefer the crimp than the screw. What I do is, I place the peeled 0 gauge onto the terminal, place it on a piece of MDF, then use a hammer to crimp. Sure, you could use heavy duty ones, but it won't justify cost.
    After I crimp, I use silver solder to make sure it don't come off.
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
    Moe Lester's Avatar
    Moe Lester is offline 1/3 of TEAM PWNAGE
    Dec 2003
    Houston, TX
    31
    3,614
    Id go for the crimp type and use a vice to do it.
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    If it is somewhere that it will be seen then I use set screw rings that match the rest of my wiring stuff. If no one will normally see the ring, then I use crimp. I care how the setup looks (for install points reasons) but if you don't compete then I would use crimp because they are cheaper. Hammer and chisel and/or vise to crimp the big ones (4ga and bigger) and a bit of solder to make sure that it's solid.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
  1. I can't crimp...even with a crimping tool
    By sumone in forum Wiring, Electrical and Installation Help
    Last Post: 02-02-2004, 07:28 AM
  2. The little screws for wire terminals!
    By EarDrummin. in forum Amplifiers
    Last Post: 01-29-2004, 12:28 AM
  3. 0/1 AWG Ring Terminals
    By awalbert88 in forum General Discussion
    Last Post: 12-14-2003, 02:10 AM
  4. Need a ring?
    By adammk5 in forum General Discussion
    Last Post: 10-31-2003, 02:25 PM
