Results 1 to 5 of 5
Reload Thread: mustang mach 460 help...
    pt123's Avatar
    pt123 is offline Junior Member
    Feb 2004
    Orange County, CA
    Hi, all. I have an 01 gt w/mach 460 system. I have hooked up my system like the one described in mustang world but I think the signal is too weak. The subs do not pound at all. I have a blaupunkt 2150 amp which puts out 400 watts rms @4ohms to the subs. The subs are 2 10-inch infinity perfects wired to 4-ohms. The amp comes with something like a line out converter as it doesn't have high level inputs. Also, the amp should turn on whenever it receives a signal but it doesn't so I had to run a remote wire. Is there a different wire that i can tap. I also tried tapping the above the rear deck and it only gave me highs. Where would the wires to the subs be from the amps? Does anyone have a wiring diagram for the rear amp/speaker configuration. Thanks in advance.
    This is the site for the mustang world install
    http://www.mustangworld.com/ourpics/fcar/despeeds1.htm
    pt123's Avatar
    Feb 2004
    Orange County, CA
    Re: mustang mach 460 help...
    I found out that the line out converter on the blaupunkt amps do not work very well. I went to Best Buy and bought a new one. They work great. I also found out that the "data cable" trick is not really a data cable. It's just the speaker wires that connect the amp to the 5x7 subs so its a regular speaker line. I found out when I aquired a wiring diagram for the system from Ford.
    badboy4life's Avatar
    badboy4life is offline Junior Member
    Feb 2004
    Topeka, Ks
    30
    Hey whats up, i had a mustang with a mach 460 systems and u just need to run the RCA cables off your CD player and if its still stock then u got to get rid of it because it wont work with the stock one and then also u need to get that done professionally because they will have a different wiring harness for u to use. trust me once i got mine all installed it kicked ***. good luck and if u have anymore question just send me a private message.
    BurntRose2's Avatar
    BurntRose2 is offline Junior Member
    Oct 2005
    Crawfordville, FL
    38
    ok mine is a convertible and i'm not completely familiar with the mach system...however...isn't the actual stereo output rca level already? why not just junk the amps and use the input wires as a low level signal straight to your amps...some soldering and you're all set? plus there should already be a remote turn on wire back there as well...afterall how do the original amps know when to activate?...all these things should be easily noticeable with a volt meter
    mobilworksaudio's Avatar
    mobilworksaudio is offline Junior Member
    Oct 2005
    Michigan
    40
    15
    http://www.mobileworksaudio.com/guid...ang01radio.htm
    This might be of help to those that have that system....
  1. Mach 460
    By kbertsch in forum Wiring, Electrical and Installation Help
    Last Post: 01-30-2004, 04:03 PM
  2. MACH 460 ADDING SUB and AMP???
    By SonicStang in forum Wiring, Electrical and Installation Help
    Last Post: 01-05-2004, 06:20 PM
  3. A Mach 460 sound system
    By DBZFB in forum Wiring, Electrical and Installation Help
    Last Post: 11-28-2003, 11:04 PM
  4. Mach 460 Harness
    By crakpotjoe in forum General Discussion
    Last Post: 10-16-2003, 11:18 PM
