Results 1 to 6 of 6
Reload Thread: 2006 Aveo Stereo Wire Harness?
    SVT99SNAKE's Avatar
    SVT99SNAKE is offline Junior Member
    Jan 2011
    Chicago
    5 Post(s)
    My uncle has a 2006 Chevy Aveo, bottom of the line version with only AM/FM radio, anyways he just bought a aftermarket CD player and I went to go hook it up and he need the wiring harness to hook up to the old white plastic clip so I can tie in the new CD player, I went to walmart and they didnt have anything so I called BestBuy and the guy told me it was around $100 for it.. I never heard of them being that much, usally $8-$20 or whatever, So I asked him why are they so much and he said everything is tied into it including fuel injectors, airbags, etc.. So my question is this all true? Is the only stereo wiring harness available over $100? Because that sounds nutts to me.. I appreciate the help..
    Sep 2006
    Brampton, ON, Canada
    27
    82
    Re: 2006 Aveo Stereo Wire Harness?
    They are ripping you, which is no surprise. The best kits model # is: BHA7200 looks like this:
    And the model number for the metra harness is: 70-8405 and this is what it looks like:
    Team Toxic Acoustiks
    Deck: Alpine CDA-9833
    Front Speakers: 4" Morel Dotech MKll Components
    Rear Speakers: 6 1/2" Powerbass 2XL Components
    Speaker Amp: Looking for one!
    Processors: Audiocontrol Matrix Line driver on the sub/speaker amp
    Sub: 12" DC Audio Level 4 Dual 1 ohm
    Sub Amp: Elemental Designs NINe.1
    Box: 3.2 cu/ft Ported Box @ 29hz
    Wire: 1/0 Welding Cable Power/Ground
    xoutofmyheadx's Avatar
    xoutofmyheadx is offline Senior VIP Member
    Jun 2010
    Romulus, Michigan
    44
    330
    1 Post(s)
    it's 100 bux cause it's tied into onstar. 1 of the wires on the new hu goes to the pink wire and you won't need the adapter. i'll find out which one gimme a few.
    Sep 2006
    27
    82
    sounds like hes got a base model, highly doubt its got on star
    Jun 2010
    Romulus, Michigan
    44
    330
    1 Post(s)
    my g/f's avalanche is an 02 and it has onstar. the harness for it was spose to cost me 130bux, but i'm in the avy forums and read to bypass it. so i did it and the kenwood works great. without it, you won't get any sound.
    Jun 2010
    Romulus, Michigan
    44
    330
    1 Post(s)
    i can't find the thread that i've seen about this before. but i believe it boils down to, you hook up the REM wire on the back of the new hu, to the pink wire on the wireing hardness going to the onstar. the pink is the amp on wire. you can only do this if you're not going to use the onstar. other than that, yes you need to buy the PAC plug if you're useing onstar, plus putting in the PAC unit will only come through the front 2 speakers (while actually talking to onstar) not all 4 for whatever reason. should double check in a chevy aveo forum to make sure this is right.
