Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Reload Thread: Wiring 5 Single voicecoil subs
  1. #16
    Delusnl's Avatar
    Delusnl is offline Senior VIP Member
    Oct 2010
    Nampa, Idaho
    370
    Re: Wiring 5 Single voicecoil subs
    Ok thanks
    Bulletproof
    _ __________,
    (__/~~`
    Refs: Resko 1 Thrice times, Whattha, Subdicted..Thats all
  2. #17
    Jul 2006
    Georgia
    12,847
    1 Post(s)
    1170 Post(s)
    It just won't work with that amp. No quoting quotes either douche
    REFS:
    Squeak9798, Kumbos310w6, BigBangTheory, Jmanpc, MillzThaYungin, WLDock, -Leister-, ThomasG, J31Rob (and a few more I have forgotten)
    Quote Originally Posted by BassAndBeer View Post
    sorry man but ford will always be a ford. ford is the sony xplod of cars and trucks. you had bad experiences with chevy because your a ford guy. its what seperates the men from the boys. friend billy use to drive a ford. he drives a chevy now. they call him billy no more. hes known as bill now..
  3. #18
    Delusnl's Avatar
    Oct 2010
    Nampa, Idaho
    370
    guess ill just have to use 4 of em for a few days!
    haha
    Bulletproof
    _ __________,
    (__/~~`
  4. #19
    DBBOOM's Avatar
    DBBOOM is offline DWN4MYN
    Oct 2008
    eastcoast
    3,629
    5 Post(s)
    That would work well, wire two in parallel on each channel.
    Natural selection at work.
  5. #20
    Nov 2010
    Brandon , FL
    36
    4,627
    10 Post(s)
    get an amp that will handle a .8 ohm load
  6. #21
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    Quote Originally Posted by DBBOOM View Post
    This is your best option. Or just wire all 4 to a 4ohm load and bridge the amp...same principle, but could make amp tuning easier being in mono mode.
    2,500+ designs since March 2011
  7. #22
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    Quote Originally Posted by Bassin Buick View Post
    Also a good option if you feel like really pushing the little buggers.
  8. #23
    DBBOOM's Avatar
    Oct 2008
    eastcoast
    3,629
    5 Post(s)
    Quote Originally Posted by RAM_Designs View Post
    True,.......................... was just trying to keep the wiring connections as simple as possible.
  9. #24
    ciaonzo's Avatar
    ciaonzo is offline TheContinental
    Feb 2009
    WI
    43
    10,996
    20 Post(s)
    1156 Post(s)
    Quote Originally Posted by Louisiana_CRX View Post
    running 5 subs ...run 4 at two ohm stereo and the 5th in at 4ohm mono this will be 3ch mode...it should work
    lulz
    Cannot believe you suggested this. I'm hoping you were going for the lulz since not only would the amplifier be seeing 1ohm per channel, the fifth driver wouldn't be stroking the same distance as the others, lol.
    In bridge mode with a 4ohm load, the amplifier sees 2ohms per channel, but with the addition of another 2ohms per channel due to the 2 sets of drivers wired to 2ohms, the amp sees 1ohm per channel. Death for the amplifier.
    You trollin'.
    Saying "clipping doesn't kill speakers" is a half-truth at best. Technically no, clipping itself does not hurt the speaker. But in clipping your amp, you can easily create a situation that WILL kill the speaker. Was the squared waveform the DIRECT cause of the failure? No. In the end, the answer is, always has been, and can only be... heat kills speakers. BUT, clipping increases heat generation, sometimes by a drastic amount. So to start a thread simply to state that clipping does not hurt speakers is, again, a half-truth at best.
  10. #25
    Delusnl's Avatar
    Oct 2010
    Nampa, Idaho
    370
    i just wired the 4 of them to 4 ohms, the subs arent even mine they are a buddies he just doesnt have an amp at the moment and we are bored....figured we would make a quick setup with them
    Bulletproof
    _ __________,
    (__/~~`
  11. #26
    ciaonzo's Avatar
    Feb 2009
    WI
    43
    10,996
    20 Post(s)
    1156 Post(s)
    Yeah, four would be the best bet.
    Is the Zapco still a looker?
  12. #27
    Delusnl's Avatar
    Oct 2010
    Nampa, Idaho
    370
    Yezzur
    Bulletproof
    _ __________,
    (__/~~`
