Results 1 to 7 of 7
Reload Thread: 2 alpine swr-1242d subs and 1 mtx thunder elite 801d amp
    bumpin420's Avatar
    bumpin420 is offline Junior Member
    Dec 2010
    Woodburn,OR
    I have 2 alpine type R subs and a mtx 801d amp. What the best way to wire them to get the best hard hitting bass from this. I listen to a lot of rap music and I like it loud. Help me out.
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    Re: 2 alpine swr-1242d subs and 1 mtx thunder elite 801d amp
    The box is the most important aspect, so long as you have halfway decent stuff. You have good subs and a good amp, you need a good box to get the most out of them. Are your subs D4ohm or D2ohm?
    2,500+ designs since March 2011
    xoutofmyheadx's Avatar
    xoutofmyheadx is offline Senior VIP Member
    Jun 2010
    Romulus, Michigan
    44
    330
    1 Post(s)
    the 4 in the modle number stands for 4ohms which means that amp you can only run those @ 4ohms. that amp can't handle a 1ohm load on it. so that amp will only push 400 to those subs. 200 to each of them. should got a different amp that can run 1000-1200 @1ohm.
    here's your wiring diagram
    http://support.alpine-usa.com/produc...12_23D_43D.pdf
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    Yeah, if they're the D4 subs you need to get a new amp that can handle a 1ohm load and give you 1kw. There are a ton of amps that can do that for you.
    bumpin420's Avatar
    Dec 2010
    Woodburn,OR
    I have a sealed sub zero box and I'm installing them in a 07 Honda accord. The subs are 4 Ohm. Head unit is a pioneer premier deh-p510ub cd player and also have a kinetik hc600 600 watt 12 volt power cell battery so my headlights don't dim..
    bumpin420's Avatar
    Dec 2010
    Woodburn,OR
    I got a brother that has a Kenwood kac-9104d amp. Would that one work?.
    Jun 2010
    Romulus, Michigan
    44
    330
    1 Post(s)
    yeah that's alot better. you'll then have 450per sub. then wire the subs like this.....
