Results 1 to 5 of 5
Reload Thread: Rear Speakers wont turn on
    kynedog's Avatar
    kynedog is offline Junior Member
    Jan 2004
    knoxville,tn
    40
    I have a 1991 Toyota 4Runner V6 SR5 4WD, and once I had a pioneer cd player, but the Rear Speakers never worked when i played it, Although they did work with the factory radio. So anyway i put the factory radio back in and the rear speakers did work. So now 2 years later i bought a JVC cd player and hooked everything up with the Car Stereo Wire Harness for my model of 4Runner, well once again the back spears arent working and I dont know what the problem is. If you could please help me figure this problem out i would greatly appreciate it.
    Thank You
    Peter Kyne
    worm's Avatar
    worm is offline Member
    Jan 2004
    NJ
    33
    60
    Re: Rear Speakers wont turn on
    take the head unit out and remove the wiring harness. check the schematics for the head unit and make sure that the colors match up for the harness for your car.
    Slody4Futbol's Avatar
    Slody4Futbol is offline CarAudio.com Elite
    Jan 2004
    Jackson, MS
    33
    1,207
    do you have a factory amp?
    fast4door's Avatar
    fast4door is offline Team Loud Concepts
    Dec 2003
    Northern VA
    34
    119
    1990-92 Toyota 4-Runner Stereo Information
    Constant 12V+ Blue/Yellow
    Switched 12V+ Gray
    Ground Brown
    Illumination Green
    Dimmer n/a
    Antenna Right Front
    Front Speakers 4" Dash
    Left Front (+) Pink
    Left Front (-) Purple
    Right Front (+) Light Green
    Right Front (-) Blue
    Rear Speakers 5 1/4" Side Panels
    Left Rear (+) Black
    Left Rear (-) Yellow
    Right Rear (+) Red
    Right Rear (-) White
    This is off the12volt.com!!
    Also if you do a search on yahoo or some other search engine for 4 runner amp bypass you should come up with some more info. Hope this helps good luck!!
    Civics are like Tampons, Every PU SSY needs one!!!
    LSCCEO's Avatar
    LSCCEO is offline Member
    Jan 2004
    Roanoke Va
    36
    42
    Right under the deck, behind all the trim is a silver box (the factory amp). There are two plugs on the bottom of it and you need both of the plugs, the small one is the rear speaker leads. When you wire it up, the wiring kit will plug into those plugs.
  1. Replies: 0
    Last Post: 01-09-2004, 04:18 PM
  2. 6x9 vs rear speakers
    By Digita187 in forum Speakers
    Last Post: 12-24-2003, 02:16 AM
  3. Rear Speakers
    By hoosierdaddy in forum Wiring, Electrical and Installation Help
    Last Post: 12-21-2003, 09:50 AM
  4. rear speakers or rear deck porting?
    By sneekerfreek in forum General Discussion
    Last Post: 11-09-2003, 12:34 PM
