Results 1 to 15 of 15
Reload Thread: I NEED WIRING HELP! MB QUART DSC 1500.1 & 2 ALHASONIC psw810's
    MRLEFTFIELD's Avatar
    MRLEFTFIELD is offline Junior Member
    Dec 2010
    Newyork
    Icon32 I NEED WIRING HELP! MB QUART DSC 1500.1 & 2 ALHASONIC psw810's
    1 MB Quart DSC 1500.1 mono amp
    1500w rms @ 1hom (stable)
    750w rms @ 2 ohm
    350w rms @ 4 ohm
    2 Alphasonic Psw810 10" subs
    800w rms each
    2 0hm DVC
    This is a question for all the car audio OGeez!
    I let this inexperience audio dude wire my system (Knew he was inexperienced when he tryed to wire each sub to its own channel. MB quart dsc 1500.1 mono amps have 2 channels but you bridge the channels to make it mono, he didnt know that) When he was finished it sounded .....ehh ok. before I bought this system off my cousin it sounded ridicolous (Clean deep lows with no distortion). Can some one help me with a diagram or any suggestions? I was thinking maybe one sub might be blown. IDK! & If I ran 1 sub @ 750w @ 2ohms would it be louder than having 2 subs split the 750 w?
    Thanks to all in advance for any advice!
    -01limited-'s Avatar
    -01limited- is online now Where are my 72 virgins?
    Oct 2010
    812 Indiana/409 Texas
    23
    3,973
    5 Post(s)
    Re: I NEED WIRING HELP! MB QUART DSC 1500.1 & 2 ALHASONIC psw810's
    That amp only has one channel. it may have two sets of outputs but its all still the same channel. just helps out with wiring options.
    2001 Jeep Grand Cherokee Limited
    Mach 5 ixl 18.4
    7 cubes tuned to 34hz
    Hifonics Brutus 2k
    Knu Wires
    Quote Originally Posted by Bassin Buick View Post
    Why?? You still haven't learned to eat my balls in the WTEMB section.
    CHUCKmfnNORRIS's Avatar
    CHUCKmfnNORRIS is offline Senior VIP Member
    Feb 2010
    CT
    323
    x2 i have the same amp
    '99 Jeep Wangler SE
    Headunit-pioneer DEH-P6900ub/bluetooth/ipod/sirius radio
    Front/Rear speakers- 6.5" infinity kappa perfect components
    Sub-12" IA Death Row
    Amp-MB Quart DSC 1500.1D(1/0 gauge wire)
    Big three- 1/0 gauge
    Dec 2010
    Newyork
    Quote Originally Posted by -01limited- View Post
    My fault I must have been miss informed but still sounds sub par to its capabilities, any suggestions on how to wire the subs to the amp and @ what ohm?
    Dec 2010
    Newyork
    Quote Originally Posted by CHUCKmfnNORRIS View Post
    How do you like it? Serving you any justice to your subs?
    Oct 2010
    23
    3,973
    5 Post(s)
    wiring options those are the different loads you can get with your subs. Which looks like you'll have to go with a 2ohm load since I highly doubt it can handle .5ohm.
    Mach 5 ixl 18.4
    Hifonics Brutus 2k
    Knu Wires
    Dec 2010
    Newyork
    Worst case scenario: If one of the subs are blown Im going to get rid of the 10's and get some dvc 4 ohm 12's so I can run the amp @ 1ohm. I was thinking either Power Acoustik FUBAR-12W or Orion XTRPRO124 or RE Audio SEX12D4? What do you think? Or suggest. Note: Im not into squares.
    Phoenix Risen's Avatar
    Phoenix Risen is offline OG.... Original Ginger
    Jun 2010
    Dayton/Springfield, Ohio
    4,014
    27 Post(s)
    wire them down to .5 and let it run, be conservative with the gains and it will do just fine, i had my dsc on a single 12 at .5 and it was fine, with the imp rise that amp will handle it fine.
    like i said just dont try to turn the gains all the way up.
    R.I.P. 2008 Hyundai Tiburon GS
    2005 Subaru Baja turbo, build in planing stages.
  9. #9
    nateberrier's Avatar
    nateberrier is offline ******
    Jun 2009
    Douche, Ohio
    4,610
    13 Post(s)
    lol also its gonna consume a ton of power at .5 lulz. ps bryan some guy wants to buy a model car or model something if you look at WTBs
    also check out the guy with the DD A4 you might be able to trade the little audio pipe for it FTW
    Quote Originally Posted by tushay4u View Post
    well i know the w7 whopms the **** out of ne other subs so give me a decent answer and stop all this denial bull just cause your poor butts can afford doesnt mean you can hate
    Refs: mrmakinmoves[SCAMMER] AKA ICHASEPAPER2010, skydeaner, fukinmovin, mossberg385t, grimreper912003, LBC99, Dbeez, Michaellane, thegreatestpenn, truckstoy, ge_off_me, btr, cupid6969, johnprdeye, jh8909, tylerj, UMWDawg92, nu2spl, zerosktr111, SPLAUDIO, $LICK CALIFA$, jfroghobo
    Team AudioTechnix
  10. #10
    Jun 2010
    4,014
    27 Post(s)
    on the note of that sucking some serious amps, what are you doing as far as electrical upgrades.
  11. #11
    Dec 2010
    Newyork
    As far as wiring
    I am currently running 4 guage to the amp and ground. I havent thought about doing the big 3 truthfully because Im on a budget and I didnt want to get that serious about my cars audio but as time goes by I want more? Would I have to get a high output alternator if I do the big 3 or will the factory alternator be sufficient?
  12. #12
    hatedonmostly's Avatar
    hatedonmostly is offline throwin' hunnits, hunnits
    Jun 2009
    Detroit, MI
    22
    6,382
    Hell no that won't run at 0.5 without some electrical upgrades, Bryan. Just add a decent sized battery in the back and do the big three
  13. Thanks MRLEFTFIELD thanked for this post
  14. #13
    Jun 2010
    4,014
    27 Post(s)
    Quote Originally Posted by allcrispedup View Post
    i know it wont run with out upgrades, that happens to be the reason that i asked him.
    and op hit up dbeez on here and see about getting one of his deka 9a31s solid batts and a great deal on them at 100 bucks
    and do the big 3 and power/grounds in 1/0 your going to need that to handle the power thats going to need
    look into knu konceptz for your wire, the have some awesome kits.i suggest the kolussus kit to the battery then get some 4g kolussus to run from the battery to the amp along with a second inline fuse holder to go close to the back battery and one to go between the battery and the amp.
    if you cant get the electrical upgrades done right now, just run the subs at 2 ohms till you can get the electrical up to snuff
  15. Thanks hatedonmostly thanked for this post
  16. #14
    Feb 2010
    CT
    323
    Quote Originally Posted by MRLEFTFIELD View Post
    i like it a lot, im only running around 800ish to a single 12" sub at 1 ohm and it does what i want it to
    '99 Jeep Wangler SE
  17. #15
    Jun 2010
    4,014
    27 Post(s)
    i loved my dsc, only reason i got rid of it is that my mmats 4000.1 showed up on the door step, had mine on a snigle 12 and did 140 legal at 40 hz
Tags for this Thread
