why do i hear a humming on my sound system, specially when i step on the gas. I have a HU, equalizer, Amp, and speakers.
thanks,
thanks,
the humming is referred to as alternator whine. you have either a cheap eq or amp, or poor grounding. bypass the EQ and see if the humming goes away, it should as inexpensive eq's are notorius for being sources of noise. if so, try adding ground loop isolation or power line filtering to the eq. if you have a pioneer head unit then ground one of the RCA shields.
and most important, ensure all equipment are well grounded. poor grounding is the #1 cause of noise.
got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
My 1966 MGB: http://www.mgexp.com/journal/keephopealive
Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
check your gains, check your gains, check your gains. after that check your gains again. than check your grounds.
Here is my feedback Thread: http://www.caraudio.com/forum/showth...ght=fasfocus00
"If you ain't cheatin', You ain't trying"
maybe theres a hummingbird trapped in your dash wanting out ....
Current 2010 Louisiana USACi State Records :
Trunk 0-1000.................. 151.3
StreetBeat 2................... 145.6
Stock 1801-up.................153.8
SuperStock 1801-up..........154.2
Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
do you listen to Crash Test Dummies? that could be the problem
Bookmarks
