Results 1 to 5 of 5
Reload Thread: 4 speakers to 2 channel amp?
    alex_321's Avatar
    alex_321 is offline Junior Member
    Nov 2010
    florida
    can i hook up 2 5 1/4 alpine type r's and to type r 6x9's to a 2channel kenwood Kac-7203.
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    Re: 4 speakers to 2 channel amp?
    Yes wire them in parallel by sides. It will put a 2 ohm load on the amp and you will lose fader (front-rear) adjustment.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
    alex_321's Avatar
    Nov 2010
    florida
    Quote Originally Posted by helotaxi View Post
    It will put a 2 ohm load on the amp .
    But will running the 4 ohm speakers on a 2 ohm load amp run correctly
    helotaxi's Avatar
    Dec 2003
    42
    8,933
    The speakers are what they are. That cannot change. The amp only "sees" the load you present it. The amp can handle a 2 ohm load. It is fine.
    Burton6431's Avatar
    Burton6431 is offline Senior VIP Member
    Jun 2010
    Ocala, Florida
    464
    youll be fine its not what the speaker can run at its about what the amp can handle, notice 2 4 ohm subs can run at 1 ohm? running the amp on a 2 ohm load will boost the power a little which youll need since your running 2 speakers per channel so the rated power will be divided by 2.
    REFS== Tone415, bigaudiofanatic, GTO Dave, deez283, DarkScorpion, Here-I-Come, ibumps, CarFanatic
Tags for this Thread
