Results 1 to 10 of 10
Reload Thread: Pioneer DVD deck question
    go5a's Avatar
    go5a is offline Junior Member
    Nov 2010
    Canada
    Hey all,
    I just bought and installed the pioneer AVH-P3200BT. My brother in law bought a no name deck from ebay that does all the same things essentially. In the no name deck's brochure it says that if you want constant video on the display to connect the brake wire (that allows only picture when ebrake is on) to the ground wire. We did that and it works fine. Could the same thing be done with the pioneer?
    Thanks for any replies
    Bad4health's Avatar
    Bad4health is offline Hymen Removal Specalist
    Sep 2009
    charlotte, NC
    888
    2 Post(s)
    Re: Pioneer DVD deck question
    some models are
    neg trigger
    pos trigger
    alternating ground trigger
    find out what one your is an you will know if u can
    itrader here: http://www.caraudio.com/forums/itrader.php?u=73815
    itrader caco: http://www.caraudioclassifieds.org/forum/itrader.php?u=5805
    itrader csco: http://www.carstereoclassifieds.org/forum/itrader.php?u=154
    ebay feedback: http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback2&userid=9845josh&ftab=A llFeedback
    go5a's Avatar
    Nov 2010
    Canada
    Quote Originally Posted by Bad4health View Post
    some models are
    neg trigger
    pos trigger
    Not quite sure what to look for. The only thing I know is it has one wire that is supposed to "crimp" onto the underside of the pull brake somehow. I haven't hooked it up yet
    thisistiny's Avatar
    thisistiny is offline Graphic Designer
    Sep 2007
    Las Vegas, NV
    458
    Pioneers made it little more difficult than grounding the parking wire. cause it has to turn the parking wire on AFTER the unit has been turned on.
    Pioneer Bypass Automatic Hack AVH-P3200BT AVH-P3200DVD - eBay (item 180568859238 end time Nov-29-10 15:59:38 PST)
    $10 bucks. it's hooked up to 12v relay. 3 wires to connect. looks easy as hell.
    Hope this helps.
    '05 Tahoe HU: Pioneer AVH-P4200DVD w/ XM add-on
    Fronts: Crescendo CCX65
    Rears: Alpine SPS-600
    Powered by: Sundown SAX-100.4D
    Subs: JL Audio 2 10w7 - 3ft^3 @ 35hz
    Powered by: Sundown SAZ-1500D
    go5a's Avatar
    Nov 2010
    Canada
    Quote Originally Posted by thisistiny View Post
    Hope this helps.
    Won't ship to Canada. Would this be the same with a toggle
    NO TICKETS BYPASS | Pioneer AVH-P3200BT AVH-P3200DVD on eBay.ca (item 180485070040 end time 18-Dec-10 10:53:39 EST)
    thisistiny's Avatar
    Sep 2007
    Las Vegas, NV
    458
    Quote Originally Posted by go5a View Post
    yepp same thing.. but i mean you can do it yourself. no need to buy this thing on ebay. look it up on youtube. good tutorials there.
    but with the switch, you gotta flip it on every time after you turn on the car.. so i'd go with the relay and get it done. just me tho.
    good luck, brotha.
    ColterDC's Avatar
    ColterDC is offline Senior VIP Member
    Jul 2009
    SLC
    36
    352
    Just go to Radio Shack and buy a $3 relay. Then wire the positive to the wire coming out of the back of the deck and then ground the other to spots on the relay.
    F-250 V10 Crew Cab with 6 inch lift
    Front and Rear Pioneer DVD screens. All stock speakers replaced with Kenwood speakers.
    2 Kenwood 10 inch subs. 2 Eclipse amps.
    Mustang GT V8
    Pioneer HU. Mach 460 stereo system. 2 MTX 15 inch subs. 1 MA Audio amp.
    Mercury Sable
    Pioneer HU. 2 Kenwood 10 inch subs. 1 SPL amp.
    nikbrewer's Avatar
    nikbrewer is offline Junior Member
    Nov 2010
    edmond, ok
    search u-tube. All you need is a relay and a few wire connectors. I just did it last week, super easy
  9. #9
    pickup1's Avatar
    pickup1 is online now Audiosystem. .
    Aug 2005
    Roanoke,TX
    48
    6,647
    17
    28 Post(s)
    i got a 4200,i put a switch on mine,works fine..just flip the switch....
  10. #10
    Louisiana_CRX's Avatar
    Louisiana_CRX is offline dem shoes...... Louisiana_CRX is a Supporting Member of the forum!
    Aug 2006
    Piney Hills of Louisiana
    34,141
    31 Post(s)
    I think most newer pioneers are pos trigger
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
