Results 1 to 2 of 2
Reload Thread: 2 Channel Amp to 2 4 Ohm Speakers
    photai's Avatar
    photai is offline Junior Member
    Jan 2004
    Miami
    Icon32 2 Channel Amp to 2 4 Ohm Speakers How to Setup?
    I think this might be a stupid question but all these RF diagrams show only 1 pos. and 1 neg. output from the amp.
    I have 2, since its a 2 channel amp. I have a Hifonics Centurion X 100w x2 @ 4 ohms amp that clams 1 ohm stable. My speakers are 2 x MTX 8000 4 ohm.
    Currently I have the speakers hooked up as follows, + from the left channel goes to both + on the speakers, - from the right channel goes to both - on the speakers. I believe this is called bridged or parallel.
    My question is, is this the best way to hook it up or am I only getting half the potential power since the - on the left and the + on the right channel are not being used? I was thinking to hook them up so that both + from the amp go to the + on the speakers in parallel and both - from amp go to the - on the speakers in parallel. Let me know if this would work. Thanks.
    nosaj070's Avatar
    nosaj070 is offline CarAudio.com Veteran
    Feb 2003
    Chicago, IL
    32
    2,393
    Re: 2 Channel Amp to 2 4 Ohm Speakers
    Nope you are the best way i believe. It is wired in parallel and bridged. When its bridged for maximum power you use the + from one channel and the - from the other.
    Alpine CDA-7995, A/D/S 3 Series Comps, ED 8A, SoundStream Reference 604, 98 Civic Sedan
    AIM: nosaj070
  1. Wiring speakers to amp and headunit??
    By llknowlesll in forum Wiring, Electrical and Installation Help
    Last Post: 12-30-2003, 10:23 AM
  2. Wire speakers to amp and headunit??
    By llknowlesll in forum Amplifiers
    Last Post: 12-30-2003, 04:20 AM
  3. 300 watt 2 channel amp, 1 ohm stable??
    By billy98sport in forum Amplifiers
    Last Post: 12-04-2003, 10:31 PM
  4. Eclipse (or any 4 channel amp) Wiring/Setup Help
    By downsider in forum Amplifiers
    Last Post: 11-16-2003, 08:25 AM
  5. Replies: 3
    Last Post: 10-22-2003, 02:23 PM
