Results 1 to 14 of 14
Reload Thread: Pulling power from amp?
    panteramatt's Avatar
    panteramatt is offline Senior VIP Member
    Jan 2004
    south jersey
    34
    161
    Im going to be putting an amp in my Yamaha Rhino atv's roof. I would like ot runs a small led dome light also. Would it hurt anything to connect the pos and neg from the light to the amp? Would put a switch inline of the pos cable to turn it off. Just dont wanna run another power wire if I dont have to. How much power would th elight pull and would it cause a spike or any porblems when running both?
    Asystole's Avatar
    Asystole is offline Member
    Sep 2010
    Pittsboro NC
    58
    Re: Pulling power from amp?
    No it wouldn't cause any problems.
    But I've gotta ask... Why would you put an amp in a rhino?
    Bought from:Travis420
    Sold to:liobeckham
    Jan 2004
    south jersey
    34
    161
    To run 2 6x9's from my ipod. Gotta have some tunes.
    FenixAudio's Avatar
    FenixAudio is offline Senior VIP Member
    Apr 2010
    Phoenix, AZ
    427
    i did a bad *** rhino install when i lived in phx. put 2 amps 4 spks 2 subs all off of an ipod hook up no deck. honestly you should be able to run the led off of the switch your installing. im gona guess the switch is gonna hook directly to the battery so current should not be an issue.
    9515ROB's Avatar
    9515ROB is offline TEAM DTF
    Jul 2009
    Sherman IL
    2,252
    19 Post(s)
    go check this out... Go to project gallery and then audio installs and click on the ranger this guy did its very impressive
    ...::: 2 Brothers Custom Trucks :::...
    - 1998 Ford Mustang -
    Head Unit: Kendwood something
    Front Stage-6.5 TREO TSX Componets
    Speaker Amp- Digital Design C4a
    Subs: 8 10" American Bass XD
    Sub Amp: 2 RD D9s
    Batts- 3 shuriken bt20 under the hood and 9 c&d 100ah batts.........15?.2 outlaw
    REFS: B:Louisiana_CRX, amartin_72, SPL KID, Bhhong, K_schutte, Fraze, hllywood29, Andrew_as,S:Jh8909 ,info,teenT:robertawdgsx
    Bumpin' Goalie's Avatar
    Bumpin' Goalie is offline Magic 8 Ball
    Nov 2009
    TN & Travel
    3,165
    You can use the amp's power/ground. Or if the dome light doesn't require much, you could even use the remote/ground wires.
    System Layout help available via PM.
    My system:
    Sounds good.
    Jan 2004
    south jersey
    34
    161
    Wow, thats a sweet install and great music too, haha. WAY too nice for wha tI do. Im building this whole thing with lights and volume control for only $80 with parts I had laying around collecting dust.
    Quote Originally Posted by 9515ROB View Post
    Jan 2004
    south jersey
    34
    161
    I would use the remote wire to the amp but thats gonna be on a switch too to turn it on and off so if i wired into that, the amp would have to be on for the light to be on.
  9. #9
    ahole-ic's Avatar
    ahole-ic is offline Banned
    Jan 2010
    Ivory Tower
    2,989
    Be careful with those rhinos. LOTS of people hook up aftermarket equipment and burn out the tiny little alt in those things.
  10. #10
    FenixAudio's Avatar
    Apr 2010
    Phoenix, AZ
    427
    do u have a deck?
  11. #11
    FenixAudio's Avatar
    Apr 2010
    Phoenix, AZ
    427
    we had a bigger alt fitted on ours
  12. #12
    Jan 2004
    south jersey
    34
    161
    No deck. Direct ipod hookup. I will have 3 gauges,1 set of hids, and the amp which is 250watts. Hopefully that wont be too much.
  13. #13
    FenixAudio's Avatar
    Apr 2010
    Phoenix, AZ
    427
    nah you will be fine. i would run a FUSED wire from the battery to the switch and switch to the light and amp turn on at the same time.
  14. #14
    BrownVanMan's Avatar
    BrownVanMan is offline CarAudio.com Elite
    May 2009
    Minneapolis MN
    1,704
    6 Post(s)
    Quote Originally Posted by FenixAudio View Post
    sounds good to me.
    i got a generic 40 watt amp thing with a 7.5 amp fuse in it i run right off a old battery that got weak and didnt fire the car up when it was -10 out with a cord that has a rca on the end and a 3.5 mm jack like your set up. hooked to 2 6x9's.
