Results 1 to 11 of 11
Reload Thread: getting 12 gauge speaker wire through door grommets
    Redford's Avatar
    Redford is offline I get angry when Im sober
    Jun 2003
    Amherst, MA
    28
    405
    basically there's a grommet on the door, then a goes through a rubber tube then through another grommet on the body of the car right next to the hinges
    I'm having trouble getting my speaker wires through, its a very tight fit and there's not a lot of room to work with. What do you guys suggest doing? I've tried using a hanger and taping the speaker wire and pulling it through but that did not work as well as I had hoped. Any other suggestions?
    I'm only using 12 gauge wire cause that's what came with the kit. Using 16 gauge would make the job slightly easier.
    1995 Camry LE 4 Cylinder Automatic Sedan
    Green Silver Pearl Metallic Clearcoat and/or Silverleaf Metallic
    No performance mods
    Clear bumper lights
    Clarion DXZ835MP
    Boston Acoustics ProSeries 6.53 in doors and Q-Logic kicks
    Polk/Momo 4 channel amp
    nosaj070's Avatar
    nosaj070 is offline CarAudio.com Veteran
    Feb 2003
    Chicago, IL
    27
    2,394
    Re: getting 12 gauge speaker wire through door grommets
    Drill a hole, and use rubber tubing from a hardware store to cover it.
    Alpine CDA-7995, A/D/S 3 Series Comps, ED 8A, SoundStream Reference 604, 98 Civic Sedan
    AIM: nosaj070
    Redford's Avatar
    Jun 2003
    Amherst, MA
    28
    405
    That's exactly what i dont want to do. I know it is possible to get it through, as many other Camry owners have done it.
    No performance mods
    Clear bumper lights
    Clarion DXZ835MP
    zane's Avatar
    zane is offline Bored.....
    Dec 2001
    Cedar Rapids, IA USA
    1,887
    Start pulling panels. Use a flat head screwdriver to pry out just the ends of the rubber hose between the door jam and the car. Feed your speaker wire into the hose and then guide it into the door. (You will have to grab the wire and pull it through into the door.) Once that is done- you are halfway home. Secure the Rubber Hose to the door again, and then feed the speaker wire through the gromet hole and into the car.
    This is where you will have to use a flashlight if needed and locate where the speaker wire enters the car.
    Generally- feed as much wire through as you can, and then look and feel under the dash for that wire. Be sure that you disconnect the - battery terminal before doing this, as there are several electrical connections under the dash.
    Running wires into the doors really isn't that bad, it's just one of those jobs that you have to struggle with once, and after you get it, it will never be a problem again.
    Webslave - www.SoundwavesCS.net
    "The man who goes alone can start today; but he who travels with another must wait till that other is ready."
    - Henry David Thoreau
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    61
    3,243
    8 Post(s)
    And unless you're running a few hundred watts there, 16 gage should be fine.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25
    Sub Stage: In process (will be Boston G310)
    Amp: Boston Acoustics GTA-704 4 Ch
    Rear Fill: Boston SE953 6X9's
    Ne1's Avatar
    Ne1
    Ne1 is offline MacDaddy lookin for the $
    Jan 2004
    Tampa, Fl
    41
    221
    Try greasing it up first? Some vaseline or lube should hook you up good.
    then just slide it on thru and clean everything up....
    conceptbassboy's Avatar
    conceptbassboy is offline Junior Member
    Jan 2004
    greenville, sc
    26
    i say run 16 guage its not gona kill you
    Redford's Avatar
    Jun 2003
    Amherst, MA
    28
    405
    the funny part is, the kicker midbass driver's i have in the doors can't even accept 12 gauge wire. But it's what came with the kit and I don't feel like buying more wire.
    No performance mods
    Clear bumper lights
    Clarion DXZ835MP
  9. #9
    RiceNotNice's Avatar
    RiceNotNice is offline Member
    Jun 2003
    la
    67
    i'd say just run 16ga. I just delt with the same issue on my 86.5 supra. HEADACHE to say the least. pull all the panels to be sure
  10. #10
    80_Cutlass_mn's Avatar
    80_Cutlass_mn is offline What needs to be here?
    Nov 2002
    Anderson,Al
    27
    1,809
    Go to best buy and go to the home theater section and look through their selection of rcas and such and you should find speaker in assorted length and guage in plastic bags. I found 100" or 50" I cant remember now I bought one or the other for only 9 bux. Good stuff too.
    Arctic White 1995 Camaro 3.4L
    Hifonics BX2005D- 12" IA Death Penalty
    Premier prs-x220 - MB Quart DSD213 components
    Pioneer DEH-P7600MP - Scosche 4 Ga. wiring kit
    Aol Instant Messanger: CamaroMN1995
  11. #11
    Redford's Avatar
    Jun 2003
    Amherst, MA
    28
    405
    Well I was able to do the passenger side by cutting the tube and doing one part and then the other. But the driver's side had even more metal in the way so I just went to the local car audio shop and had them do it for me... they charged $15, which is a little much I guess but saved me from hours of frustration. Now I'm having trouble getting the carpet back over all the wires so that it snaps back into place. I can't get the trim back in cause of that and that means I can't get the kickpods in so I'm running midbass in the door and stock rears Gonna have someone clean it up for me since I'm too frustrated with it.
    No performance mods
    Clear bumper lights
    Clarion DXZ835MP
  1. Can I use 10 gauge wire for my power
    By howler2004 in forum Wiring, Electrical and Installation Help
    Last Post: 06-24-2004, 06:24 PM
  2. choosing wire gauge!
    By candy cutlass in forum Wiring, Electrical and Installation Help
    Last Post: 01-19-2004, 03:55 AM
  3. speaker wire
    By KARLEON in forum Wiring, Electrical and Installation Help
    Last Post: 01-06-2004, 12:45 AM
  4. Can speaker wire be too big?
    By davidfre21 in forum General Discussion
    Last Post: 09-30-2003, 11:01 PM
  5. wire gauge
    By confusedone in forum Wiring, Electrical and Installation Help
    Last Post: 08-20-2003, 01:13 PM
