Page 8 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 106 to 120 of 151
Reload Thread: Why is my voltage drop so awful?
  1. #106
    hatedonmostly's Avatar
    hatedonmostly is offline throwin' hunnits, hunnits
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Re: Why is my voltage drop so awful?
    I'm going to cut and restrip my power and ground to the amp, along with replace the fuse in the distro. If that doesn't fix it, I'm putting the other alt in. If that doesn't fix it, I'm selling everything, lol.
  2. #107
    Jan 2008
    Mt. Vernon, IL
    826
    Quote Originally Posted by Still View Post
    Didn't help at all.
    When idling and nothing playing, the front battery was reading different than the rear battery and the amp, which were reading the same. When playing full tilt the amp was dropping to 11.5 (it's hotter today, than before) and the rear battery was dropping to 12.7. There's still a difference between the two, although there shouldn't be.
    I think it's time for some pictures of the wiring and connections. There is high resistance or this would not be happening. In a parallel circuit the voltages will be the same unless there is some resistance in series (in a run of wire). I am curious. If you unhook your amp, do the batteries read the same voltage then? If so, then connect the amp again but unhook the remote lead. Now are the batteries the same? If they are still the same, you need to have someone with a DC clamp meter, see what your amp is drawing with no music. If it's drawing greater than an amp or two when not playing anything it needs to be repaired.
  3. Thanks hatedonmostly thanked for this post
  4. #108
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Quote Originally Posted by eCrack View Post
    Do you mean with the car running or off? Running I assume? Unfortunately, I don't know anyone with a clamp meter, so let's go through the first couple of steps first...
  5. #109
    BrownVanMan's Avatar
    BrownVanMan is offline CarAudio.com Veteran
    May 2009
    Minneapolis MN
    2,018
    1 Post(s)
    331 Post(s)
    with no music truck running what voltage to you get at front and back battery.
  6. Thanks hatedonmostly thanked for this post
  7. #110
    jco1385's Avatar
    jco1385 is offline expert jcologist
    Sep 2007
    Mobile, AL
    18,860
    4 Post(s)
    644 Post(s)
    car running, yes. i think you can do what he's saying by pulling the remote and checking. if the same numbers, then re-connect the remote. if that doesnt make a difference, then get the amp checked. testing for a bad amp...
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
  8. Thanks hatedonmostly thanked for this post
  9. #111
    Jan 2008
    Mt. Vernon, IL
    826
    Quote Originally Posted by jco1385 View Post
    Exactly. We are going to get this thing solved. We just have to narrow it down first.
  10. Thanks hatedonmostly thanked for this post
  11. #112
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Okay guys:
    Testing with car on, HU on, HU volume at 0, remote hooked up:
    Front battery: 13.68-13.69
    Rear battery: 13.64-13.65
    Testing with car on, HU on, HU volume at 0, remote NOT hooked up:
    Rear battery: 13.67-13.68
    Resistance in the wire connecting the two batteries? I can check my solder joints, since I may have done a bad job on them...
  12. #113
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,860
    4 Post(s)
    644 Post(s)
    Okay guys:
    that resistance might be the length of the wire. it's not much. the resistance you're worried about is between the amp and the rear battery. or maybe internally in the amp. how big is your alt? that should be closer to 14.4v w/ the car running.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  13. Thanks hatedonmostly thanked for this post
  14. #114
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    It's only an 18' run.
    Alt is an aftermarket 136A, but it's a factory replacement, not a true aftermarket designed for car audio. My true OEM alt used to charge at 14.4 during the winter, and as it warmed up it dropped to 13.9. Since then it's dropped further, although it's only gotten cooler out.
  15. #115
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,860
    4 Post(s)
    644 Post(s)
    hmmmmmmmmmmmmm....... do that same test as up there ^^^ but also measure at the amp. a .01v drop over 18' isn't a worry. i'm curious what the voltage is at the amp with the amp on, volume down VS amp off (remote unhooked). should be very similar and should be the same as the battery shows. might need to find a clamp, or maybe swap a different amp in to try?
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  16. #116
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    I don't have another amp that draws this much current, nor can I find a clamp meter. :/ I'll try that.
  17. #117
    Jan 2008
    Mt. Vernon, IL
    826
    Okay guys:
    This shows the amp is good, the wire has high resistance somewhere. This happened to one of my dad's hi performance CB installs. He was a die hard solderer until we had this same problem. We replaced it all with crimp ons and it fixed it. That SHOULDN'T happen, but sometimes it does.
  18. #118
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Front battery: 13.75
    Rear battery: 13.72
    Amp: 13.68
    Rear battery: 13.74
    Amp: 13.74
  19. #119
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Honestly, I didn't know the first thing about soldering, I just started doing it on all my lugs one day. I didn't know what a cold solder joint was or what causes it until you mentioned it in this thread. After having learned a thing or two I'm sure that my technique has improved, and I should resolder these terminals.
    Can old solder or lugs that have been reused multiple times cause this?
  20. #120
    Slo_Ride's Avatar
    Slo_Ride is offline Take It Easy
    Oct 2005
    Back to ATL
    13,033
    33 Post(s)
    3127 Post(s)
    Lord have mercy, I'm gonna have to read this whole thing. I cant believe nobody's got this straight yet.
    Soldering is overrated. No is the answer to your question.
    Refs = PapaGeno21, Goindef154, 92c1v1c, Disarmer, chemmins, 97maxima, kroid777, ithertz, basscort2009, hunterw, mar08052, appleyard, millimac247, jonny101abc, sundownz, cranberryyumyum, mig139, daboyfrumdabx, skateguy92, basebalz13.
