Page 4 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 46 to 60 of 151
Reload Thread: Why is my voltage drop so awful?
  1. #46
    Jan 2008
    Mt. Vernon, IL
    826
    Re: Why is my voltage drop so awful?
    Quote Originally Posted by Still View Post
    Yes, a small difference. All my connections are soldered...
    I'm talking about with the car running.
    I know you're talking about with the car running, so how could the batts keep the voltage above 12.6v?
  2. #47
    hatedonmostly's Avatar
    hatedonmostly is offline throwin' hunnits, hunnits
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Quote Originally Posted by branham1127 View Post
    You need to listen to people and ground your rear battery somewhere else. The bed of a truck is not a good ground. Many people (such as yourself) fail to realize how important the ground is in a car electrical system. I really think this will solve the problem of the voltage difference.
    Oh, I realize how important it is...but logically, if I'm not seeing any difference in voltage between the front and rear batteries, I'd think it should be a good ground. I've posted that multiple times, and no one has said anything about it being right or wrong. I'm not just trying to solve the problem, but I also want to understand it too...
    I do believe that is my remaining option, so tomorrow I'll be up early to try that...
  3. #48
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Quote Originally Posted by eCrack View Post
    Alternator charging them?
  4. #49
    l7runner's Avatar
    l7runner is offline Amidst the Static
    Jan 2008
    NC
    1,005
    I have had seemingly "good" grounds that were actually terrible. Change your rear ground and test the resistance between that point and your front battery's negative terminal.
    It would be best to grab some more wire and run it all the way to the front batt to avoid all of these issues.
    HU: Pioneer 880-prs
    Mid/High Amp: MB Quart DSC4125
    Front Stage: PG mids/Vifa tweets running active
    Sub Amp: DD Z1
    Sub: 10" Mach 5 SPL/Hybrid 1.25ft^3 @ 38hz
    DC Power Alt
  5. #50
    Jan 2008
    Mt. Vernon, IL
    826
    They don't charge to 14.4v. They charge to around 12.6-12.8v. They can float up to 13's, but they rest and discharge most of their current at 12.6-12.8v. So, since they do basically nothing above 12.6v, I again ask how could batts help above 12.6v?
  6. #51
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    To the bed of the truck, paint sanded and bolted down. I know it's not to the frame, but my frame is rusty and I didn't think it mattered because I was getting the same resting voltage on both batteries.
    Moving it to the frame could be the difference.
    2,500+ designs since March 2011
  7. #52
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    And x2 to the batts not helping above ~13V, anything above that is all on the alty until voltage drops to battery level.
  8. #53
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Quote Originally Posted by l7runner View Post
    Eventually I will, if this works.
  9. #54
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    I don't understand this...
    Quote Originally Posted by RAM_Designs View Post
    I'm kinda skeptical about it being the cure-all for all of my problems, but it's all I have left to try...
  10. #55
    Jan 2008
    Mt. Vernon, IL
    826
    LOL. This HAS to be a troll thread. Is this slappin?
  11. #56
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    No?
  12. #57
    Jan 2008
    Mt. Vernon, IL
    826
    No?
    Then what don't you understand about batts don't charge to 14.4v?
  13. #58
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    ****, my bad. I know the batteries themselves do not charge to 14.4v, but the charging system runs at 14.4. A bit of miscommunication there...
    So basically, if you don't have a HO alt up front, no matter how much reserve you have in the rear, you're always going to have voltage drop?
  14. #59
    9515ROB's Avatar
    9515ROB is offline TEAM DTF
    Jul 2009
    Sherman IL
    2,299
    57 Post(s)
    is your wire directional that might add a little resistance
    still have alot of stuff i need to invest in
    880prs/Front-Hybrid Audio Technology Legatia L8 L3 L1v2 3-way/Sub- 3 blown MB Quart RLP-304 shallow mount 12s/Sub Amp- Visonik v2908/4ch- DD C4a
    REFS: B:Louisiana_CRX, amartin_72, SPL KID, Bhhong, K_schutte, Fraze, hllywood29, Andrew_as,S:Jh8909 ,info,teenT:robertawdgsx
  15. #60
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Quote Originally Posted by 9515ROB View Post
    Nope.
