Page 3 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 31 to 45 of 151
Reload Thread: Why is my voltage drop so awful?
  1. #31
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    Re: Why is my voltage drop so awful?
    Quote Originally Posted by eCrack View Post
    There is obviously high resistance between the rear batt and the amp. If you're dropping .2 and there is no current being drawn, that is bad. In a parallel circuit the voltage should be the same. It's only once you start drawing current that the resistance of the wire should become evident. You need to either shorten the run from the back batt to the amp, or shorten the ground or both... or tighten something. It's right there. It can't be anything else.
    This.
    How are you grounding your amp and where is it grounded to? I assume you're sending the ground from the amp to the rear batt and grounding the batt somewhere, correct?
    2,500+ designs since March 2011
  2. #32
    hatedonmostly's Avatar
    hatedonmostly is offline throwin' hunnits, hunnits
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Quote Originally Posted by RAM_Designs View Post
    This.
    Unfortunately, no. Amps are grounded in the cab and batt is grounded in the bed...
  3. #33
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    hmm...that might be your problem
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
  4. #34
    SpeedEuphoria's Avatar
    SpeedEuphoria is offline CarAudio.com Elite
    Jun 2010
    BCM
    575
    I say grounding also
    BUT
    Whats the voltage with the car on? I never saw that, but prob not the issue as from what I under stand with the truck not running your getting a V drop of almost 1volt(from 12.6x down to 11.8v) or is that with the truck running, which would mean something is no good.
    May have to run another 1/0 ground up to the front
    03 Dodge Stratus Coupe SXT
    89 Dodge Spirit 10's or Bust!!
    http://www.cardomain.com/ride/2641801
  5. #35
    stereohead69's Avatar
    stereohead69 is offline Senior VIP Member
    Sep 2009
    oswego ny
    38
    204
    23 Post(s)
    You said your wire you bought off of Ebay what is the brand of wire since i know that companies like Pyramid,Rampage,Legacy,Lanzar to name a few when you buy from them a 4 guage kit when you get it its more like 8-10 gauge i dont know if that might be your prob but i would check it out.
  6. #36
    l7runner's Avatar
    l7runner is offline Amidst the Static
    Jan 2008
    NC
    1,005
    Ground amps to the rear batt.
    If possible do a ground run from front to rear batt. This should solve all of your issues.
    HU: Pioneer 880-prs
    Mid/High Amp: MB Quart DSC4125
    Front Stage: PG mids/Vifa tweets running active
    Sub Amp: DD Z1
    Sub: 10" Mach 5 SPL/Hybrid 1.25ft^3 @ 38hz
    DC Power Alt
  7. #37
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Quote Originally Posted by Buck View Post
    Quote Originally Posted by l7runner View Post
    Indeed, it seems so....
    Quote Originally Posted by SpeedEuphoria View Post
    BUT
    Oddly, voltage with the car on is only 13.6 with the car warmed up. Pretty ******.
    But yes, the voltage drop I described was with the car on.
    Quote Originally Posted by stereohead69 View Post
    When did I say anything about eBay in this thread? I run Knukonceptz everything...
  8. #38
    Imtjnotu's Avatar
    Imtjnotu is offline Me Gusta Edition
    Nov 2006
    San Diego CA
    12,626
    1589 Post(s)
    RUN 0 gauge and check all ur grounds also get a dmm and check ur alternator
  9. #39
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Okay, so:
    -Grounded the amps at the battery, didn't help.
    -Tossed in a buddy's 110ah battery to see if it was the battery was bad, I was still dropping to 12v. So rear battery I had in must be fine.
    -Took the rear battery out, and the voltage drop did not change at all, or at least, very very little. Still dropping to 11.8-9.
    -Checked various voltages. At full tilt I'm dropping to 11.8 at the amp, 12.0 at the in side of the distro for the amp, and 12.8 at the rear battery. Somehow I'm losing 1v between the battery and the amp, yet why should I even be dropping to 12.8 at the battery in the first place?
    Alt not charging perhaps? If not then I give up
  10. #40
    Jan 2008
    Mt. Vernon, IL
    826
    Quote Originally Posted by Still View Post
    Okay, so:
    So you connected the amp to the rear batt, and there was still a voltage difference? If so, your wires are either too long or you have a bad crimp or something is high resistance there. Also, batteries only charge up to about 12.6, how the hell could they help keep your voltage up above that? lol
  11. #41
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Yes, a small difference. All my connections are soldered...
    I'm talking about with the car running.
  12. #42
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    Where exactly is your rear batt grounded in the bed?
  13. #43
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    To the bed of the truck, paint sanded and bolted down. I know it's not to the frame, but my frame is rusty and I didn't think it mattered because I was getting the same resting voltage on both batteries.
  14. #44
    Jul 2006
    Georgia
    12,847
    1 Post(s)
    1170 Post(s)
    Quote Originally Posted by Cruzer View Post
    my alt is 136a, stock battery, random ebay 4 guage wire, AQ1200D amp, 14.4 volts.
    BIG 3??? who needs it???
    seriously idk whats wrong, i just measured mine yesterday and i got literally 14.4 -14.2 volts right at the amp, i ran a single long wire from batt under all my side panel stuff, all the way to the amp. no fuses, no distro block.
    Idiot.
    REFS:
    Squeak9798, Kumbos310w6, BigBangTheory, Jmanpc, MillzThaYungin, WLDock, -Leister-, ThomasG, J31Rob (and a few more I have forgotten)
    Quote Originally Posted by BassAndBeer View Post
    sorry man but ford will always be a ford. ford is the sony xplod of cars and trucks. you had bad experiences with chevy because your a ford guy. its what seperates the men from the boys. friend billy use to drive a ford. he drives a chevy now. they call him billy no more. hes known as bill now..
  15. #45
    branham1127's Avatar
    branham1127 is offline Matt Branham
    Jul 2008
    Colorado
    29
    346
    You need to listen to people and ground your rear battery somewhere else. The bed of a truck is not a good ground. Many people (such as yourself) fail to realize how important the ground is in a car electrical system. I really think this will solve the problem of the voltage difference.
    2003 Chevy Silverado Ext Cab
    Head Unit: DNX-9960
    Mids/Highs: (2) pair of ID CXS64 V.2
    Mids/Highs Amps: American Bass SQ-945
    Subs: Pair of DC Lvl 5 18s
    Sub amp: American Bass 700.1
    260 amp Iraggi alternator (6) neg/ (6) pos Kicker 1/0
    D2400 Under the hood (6) D3100s, XS Power VCM
    Refs: http://www.caraudio.com/forum/buyer-seller-feedback/463207-branham1127-feedback-thread.html
