Originally Posted by
lostdaytomorrow
I felt the same way when I had Voltage problems a while back. You will be back.
You need to run two runs of 1/0 awg from your front batt. to rear batt.
You need one positive run and one neg. run from front batt to rear batt.
You need to wire your amp directly to the rear batt postive and negative.
Make sure your alt is upgraded 1/0 awg to the front batt. as well as 1/0 awg from negative alt. (case of alt.) to negative of battery.
Just take your rusty truck frame out of the equation all together.
Bookmarks
