Page 10 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 136 to 150 of 151
Reload Thread: Why is my voltage drop so awful?
  1. #136
    FlexnInLa's Avatar
    FlexnInLa is offline Huggin Them Nuts!
    Jul 2010
    Middle of Nowhere, Louisiana, USA
    45
    1,243
    232 Post(s)
    Re: Why is my voltage drop so awful?
    1/0 Big Three, check all your grounds and connections.
    New ride... new system...
    2012 Jeep Compass Latitude
    18" Obsidian Audio Sub in a Reverse Tapered Transmission Line Box
    Box Design by Mobile Enclosures http://mobileenclosures.jimdo.com
  2. #137
    FlexnInLa's Avatar
    Jul 2010
    45
    1,243
    232 Post(s)
  3. #138
    Jan 2008
    Mt. Vernon, IL
    826
    Quote Originally Posted by FagDouche View Post
    Way ahead of you pal.
  4. #139
    Slo_Ride's Avatar
    Slo_Ride is offline Take It Easy
    Oct 2005
    Atlanta
    13,392
    35 Post(s)
    3263 Post(s)
    until you figure out where the problem is i wouldnt worry about soldering anything, besides nothing is better than a straight copper to copper connection.
    Refs = PapaGeno21, Goindef154, 92c1v1c, Disarmer, chemmins, 97maxima, kroid777, ithertz, basscort2009, hunterw, mar08052, appleyard, millimac247, jonny101abc, sundownz, cranberryyumyum, mig139, daboyfrumdabx, skateguy92, basebalz13.
  5. #140
    Jan 2008
    Mt. Vernon, IL
    826
    Quote Originally Posted by Dpc69ss View Post
    All of his connections are soldered right now. Also, AQ might say that but it does not make it true. You can't beat soldering if it's done right.
  6. #141
    Slo_Ride's Avatar
    Oct 2005
    Atlanta
    13,392
    35 Post(s)
    3263 Post(s)
    Quote Originally Posted by eCrack View Post
    I know, that's what I'm saying, get a foot of wire and straight wire the amp and see if you still get the drop. I can beat soldering, but I'm not knocking it if done right. I'm just saying it isn't really necessary. Also I'm not one for listening, I prefer to find things out the hard way, so I couldn't tell you what AQ sez.
  7. #142
    lostdaytomorrow's Avatar
    lostdaytomorrow is offline CarAudio.com Elite
    Oct 2006
    Loc
    1,569
    2 Post(s)
    Holy ****ing **** how is this not solved yet? 5 ****ing pages?
    It's your grounds.
    You need + and - 1/0 awg or larger from front batt to back batt.
    Ground amp at the rear battery.
    If you still have issues; bad alt, bad batt(s), bad ring terminal connections.
    Also, soldering ***** compared to a proper crimp, but proper crimps are pretty tough to do on 1/0 awg and larger without the proper tools.
    References: Vitveet x2, massiveaudiocw, n00b, darren700, Beerdrnkr, brchd, Mr. C, Raamaudio, h8ter, cman9012, Millertime1028, Teamsubgopoof, ABSOLUTEAUDIO, DB_DRAG_SPL, ls2poweredgoat, RyanM923, Worstenemy453, Connersdad19, pickup1, wgsj_fortvalley, ellocojorge
  8. #143
    jco1385's Avatar
    jco1385 is offline expert jcologist
    Sep 2007
    Mobile, AL
    18,862
    4 Post(s)
    644 Post(s)
    OP, did you ever crimp them shits? let's put this to rest.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
  9. #144
    Aug 2010
    Knoxville, TN
    30
    9 Post(s)
    Didn't read through everything, but I can tell you a few problems to begin with.
    If your batteries are only resting at 12.6V then they are either bad or you are not getting them fully charged. A 12V battery is fully charged at 12.9V with optimal charge voltage of 14.4V. If your connections are good and your ground it good, then you should see the same voltage at your alternator, your front battery, and your back battery. Your amp should be getting the same power as your back battery, or within a tenth or so.
    Best way to test the batteries is either take them to an auto parts store and have them hook the batteries up to the Midtronics tester (takes about 1min to test them), or pull them out and fully charge them with a good charger. A fully charged 12V battery just off the charger should be around 14.4V and after sitting for about 12 to 24 hours it should be resting at around the 12.9-13.2V range. If the battery drops down to the low 12 to high 11V range then you have at least one bad cell in the battery.
    AH has NOTHING to do with batteries when it comes to car audio applications. AH ratings are low amperage pulls for extended periods of time. Car audio has high amperage pulls for short periods of times. So, unless you are using the battery to run a 10amp light for 20hours the AH means nothing.
  10. #145
    hatedonmostly's Avatar
    hatedonmostly is offline throwin' hunnits, hunnits
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Quote Originally Posted by jco1385 View Post
    Gonna see if I have time today.
  11. #146
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Crimped the wire from the rear battery to the amp, didn't do anything. I'm not going to unsolder all of my connections and crimp them because obviously the problem lies in that wire alone. Since that didn't fix it, there's nothing more I can do.
    PM me if you want some of the equipment in my sig, because I pretty much give up on CA. Dropping to fucking 11.7 with only 1k.
  12. #147
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,862
    4 Post(s)
    644 Post(s)
    weak jooce. you do power and ground wires?
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  13. #148
    Oct 2006
    Loc
    1,569
    2 Post(s)
    Quote Originally Posted by Still View Post
    I felt the same way when I had Voltage problems a while back. You will be back.
    You need to run two runs of 1/0 awg from your front batt. to rear batt.
    You need one positive run and one neg. run from front batt to rear batt.
    You need to wire your amp directly to the rear batt postive and negative.
    Make sure your alt is upgraded 1/0 awg to the front batt. as well as 1/0 awg from negative alt. (case of alt.) to negative of battery.
    Just take your rusty truck frame out of the equation all together.
  14. #149
    Slo_Ride's Avatar
    Oct 2005
    Atlanta
    13,392
    35 Post(s)
    3263 Post(s)
    Quote Originally Posted by lostdaytomorrow View Post
    do it
  15. Thanks lostdaytomorrow thanked for this post
  16. #150
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    What issues were you having?
    I for sure want to do this, but not sure if that is truly the problem that I am having. The last thing I want to do is spend a ton on wire if it doesn't help.
    A buddy told me that it may be because the alt doesn't have enough power to charge both batteries and the amp. But this shouldn't matter, because I should be getting the same voltage at the amp and the battery, correct?
    Also, if batteries and amps should read the same voltage, why do some people have multiple volt meters hooked up to both amps and batteries? Confusing...
