Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Reload Thread: Volume up, Bass gone!!!!
  1. #16
    ascitiesburn69's Avatar
    ascitiesburn69 is offline CarAudio.com Elite
    Jul 2008
    New Orleans, LA
    558
    Re: Volume up, Bass gone!!!!
    Well, You could have accidently touched the positive to the case of the amp which is also a ground and would more than likely blow the fuses in the amp. Check the fuses in the amp and also the one under your hood. (assuming you have one of course).....
    HU: Alpine 9887
    Subs: 4x SA10s
    Amp:Audioque 3500.1 at .5
  2. #17
    Marquise's Avatar
    Marquise is offline Junior Member
    Jul 2010
    fort worth, tx
    29
    how do i wire them to a hire ohm
    Why?
  3. #18
    bubbagumper6's Avatar
    bubbagumper6 is offline CarAudio.com Veteran
    Apr 2006
    The D
    11,052
    897 Post(s)
    Quote Originally Posted by Marquise View Post
    Don't listen to that kid, he's an idiot. First and foremost, whenever your working on ANY kind of electrical wiring in your car you need to disconnect the battery. Having your positive wire in the amp be live when you stuck the ground back in there is a no-no. Next, I assume you have a multimeter (if not, go spend the $5 at walmart and get one). The easiest thing to start narrowing down what's broken is to check voltages. Check the voltage at your amp, if you still have +12V on your power wire and remote turn on, but the amp isn't turning on, then you know there is something wrong with the amp. If your not getting 12V at the amp then you know there's a problem in your power wire somewhere (probably a blown fuse or bad connection somewhere)
  4. #19
    Marquise's Avatar
    Jul 2010
    fort worth, tx
    29
    i think i might have blown a fuse......just gotta figure which one it is
    Why?
  5. #20
    quins90lac's Avatar
    quins90lac is offline CarAudio.com Elite
    Jun 2008
    peoria IL
    1,783
    8 Post(s)
    You broke you **** homey.
    no links in sigs is FUCKING BULLSHIT
    bought from. chereck04, etznova, matthewo, parker G, 4ozgloves
    Car 1990 Cadillac Sedan Deville
    HEADUNIT Pioneer deh8600mp
    Front stage pioneer 6.5 coax
    Rear stage pioneer 6x9 coax
    Sub Amp PA AB3000D at 2ΩRIP
    now soundstream pxc2000d at 2Ω
    Subs RE SE D2Ω X2 FRIED 1 now PSI D1Ω X2
    ElectricalEA 250 alt kun KLMX wire YT front bat stinger spv70 rear
Tags for this Thread
