Results 1 to 10 of 10
Reload Thread: 15.15 volts
    idontwant1's Avatar
    idontwant1 is offline Member
    Dec 2003
    the megacity
    55
    15.15 volts
    just installed my new alternator on my lincoln and with my voltmeter hooked up its reading 15.15 volts. should i be alarmed the cars a 75 so it has no computers or electronics just my alpine hu and amps and stuff ....also i get 13.8 volts at the battery car off
    nosaj070's Avatar
    nosaj070 is offline CarAudio.com Veteran
    Feb 2003
    Chicago, IL
    32
    2,393
    Re: 15.15 volts
    Thats really interesting...i know most car batteries are 12v, and nothing more. But i believe there are higher current ones, which you may have. It also is possible for an alternator to put out that much, it also helps not having any loads drawn from the cars onboard components. But i think if none of hte above apply to you, maybe do you have the multimeter on the wrong setting?
    Alpine CDA-7995, A/D/S 3 Series Comps, ED 8A, SoundStream Reference 604, 98 Civic Sedan
    AIM: nosaj070
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,015
    1 Post(s)
    265 Post(s)
    Re: 15.15 volts
    I would guess that it's just an inaccuracy in the meter since both measurements are unusually high.
    idontwant1's Avatar
    Dec 2003
    the megacity
    55
    Re: 15.15 volts
    im going to get another meter later but i think this ones good ...
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    Re: 15.15 volts
    With no load and a freshly charged battery, 13.8 volts is not uncommon. For the alternator, it sound like your voltage regulator might be off but under a no load condition it could run a bit higher as well.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
    idontwant1's Avatar
    Dec 2003
    the megacity
    55
    Re: 15.15 volts
    i found my other tester so ill try it again and ill try it with the headlights on ill report back im a few
    idontwant1's Avatar
    Dec 2003
    the megacity
    55
    Re: 15.15 volts
    i just treid my other tester and it gave me readings im more familliar with .....imagine that i have a digital tester thats off that much ....
    helotaxi's Avatar
    Dec 2003
    42
    8,933
    Re: 15.15 volts
    Did you try both testers with the headlights on? Just curious.
  9. #9
    idontwant1's Avatar
    Dec 2003
    the megacity
    55
    Re: 15.15 volts
    i didnt try either with the lights on
  10. #10
    95RAM's Avatar
    95RAM is offline CarAudio.com Elite
    Nov 2003
    Jensen Beach, Fl
    31
    605
    Re: 15.15 volts
    why is it because a battery says 12 volts they assume that it must have 12 and only 12 volts?
  1. need a 1500 watt amp rated at 12 volts.
    By cobra65427289 in forum Amplifiers
    Last Post: 01-08-2004, 10:47 PM
  2. Need more volts!
    By Daniel in forum General Discussion
    Last Post: 11-24-2003, 04:01 PM
  3. Wiring 4 jl subs
    By Gaffney982 in forum Wiring, Electrical and Installation Help
    Last Post: 10-09-2003, 08:36 PM
  4. Rated RMS vs Actual RMS
    By Forty-Ouncer in forum Amplifiers
    Last Post: 10-02-2003, 02:26 AM
