Results 1 to 5 of 5
Reload Thread: Amp->Subs question
    Bumpin_Ack's Avatar
    Bumpin_Ack is offline Senior VIP Member
    Dec 2003
    SLC Utah
    30
    170
    Amp->Subs question
    Is 12awg wire thick enough, i'll be using a kx600.1 to power 2 (12) Kicker Comp Vrs. Oh and wiring them, I have to dual 2 ohm versions and plan on wiring them like this but my question is where the wires going from the amp to the subs, where they branch off. Is it okay to run pos/neg to the first ring terminal, then a seperate wire from that same ring terminal to the second, or will the 1st sub end up with more power?
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    Re: Amp->Subs question
    12ga will be plenty. As for the routing of the wiring, as long as the dual coils of each sub are wired in series as shown in the diagram, you can either run the wire to the first sub's pos and neg and the to the second sub's pos/neg, run two sets of wire to the amp, or run wire from the amp to a barrier strip and then on to each respective sub. Any of the above will result in the parallel wiring of the subs. Electricity depends on relative resistance, not order of routing fro determining power distribution, so just cause it is wired a bit closer doesn't mean it will get more power.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
    Bumpin_Ack's Avatar
    Dec 2003
    SLC Utah
    30
    170
    Wait so let me make sure this is okay. I run a wire from the pos/neg of my mono amp, to pos/neg of sub #1. Then can i just take another wire and wire pos/neg of sub #1 to sub #2...? Correct me if i am wrong.
    Bumpin_Ack's Avatar
    Dec 2003
    SLC Utah
    30
    170
    ^Bump^ it to the top
    helotaxi's Avatar
    Dec 2003
    42
    8,933
    Quote Originally Posted by Bumpin_Ack
    You are not wrong so I will not correct you
  1. amp question
    By scono in forum Amplifiers
    Last Post: 03-11-2004, 05:44 AM
  2. Question about my 2 ch amp
    By liqdsm in forum Wiring, Electrical and Installation Help
    Last Post: 12-19-2003, 11:31 PM
  3. quik mono amp question
    By stangpounder in forum Wiring, Electrical and Installation Help
    Last Post: 11-16-2003, 08:08 PM
  4. Amp wiring question
    By Dookie in forum Amplifiers
    Last Post: 11-13-2003, 10:36 PM
  5. stock amp question
    By goodstuff in forum Wiring, Electrical and Installation Help
    Last Post: 10-23-2003, 05:03 PM
