Results 1 to 3 of 3
Reload Thread: NEED TO KNOW! Quick wiring question! Help!
    jackattack's Avatar
    jackattack is offline Junior Member
    Jul 2010
    the couve
    1989 honda crx
    connecting kenwood kdc-mp245
    have to hardwire into car, no harness
    have the speaker and ground connections figured out.
    I need to know which connection goes where: connect the (Battery/YELLOW) wire and (Ignition/RED) wire INTO either the (RED/YELLOW Main stereo supply/radio switched 12v+) or the (WHITE/GREEN Constant power 12v+).
    rosshimself13's Avatar
    rosshimself13 is offline Senior VIP Member
    Nov 2009
    GC, il
    357
    Re: NEED TO KNOW! Quick wiring question! Help!
    Quote Originally Posted by jackattack View Post
    did you even think for more than 5 seconds about this question?
    connect the (Battery/YELLOW) wire (WHITE/GREEN Constant power 12v+).
    (Ignition/RED) (RED/YELLOW Main stereo supply/radio switched 12v+)
    Quote Originally Posted by oldschoolboomer View Post
    well the 2 round twelves are pie r square and the l7's are already square so they would hit way harder especially when your amp puts out square waves which I assume is quite often
    bought from: PioneerSPL1990, galacticmonkey, Plottin4sucess, djarmy2004, michaellane, slam, k_schutte, theMessenjah44
    jackattack's Avatar
    Jul 2010
    the couve
    wow that was really rude.
    hope you feel good about yourself.
    thanks for you response, assanine though it may be.
    after a little more research i solved the problem, and came up with the same solution. thanks for taking the time to be a nice guy, and a **** all at the same time.
Tags for this Thread
