Results 1 to 4 of 4
Reload Thread: 5 channel amp and 6 speakers plus sub?
    bbroge's Avatar
    bbroge is offline Junior Member
    Jun 2010
    Madison, WI
    Ok, so I have the following:
    Infinity Kappa Five Amp
    Kappa 693.9i 6x9 Speaker Pair (2ohm impedance)
    Kappa 462.9cfp 4x6 Pair (2ohm impedance)
    Kappa 6-1/2" 3-way Speaker Pair (2ohm impedance)
    Right now I basically have the amp in a standard 5 channel operation:
    Two 6x9 speakers are connected to rear amp channel, sub is connected to sub channel, and the 6x9 are connected to front channel.
    Can I safely connect the two 4x6 speakers to the same channel my 6 1/2 are connected to at the same time?
    I found this in my amp manual-
    Minimum speaker impedance for stereo operation is
    2 ohms. Minimum speaker impedance for bridged
    operation is 4 ohms. Minimum subwoofer impedance
    is 2 ohms.
    So if I connect the 4x6 in series it would equal 4 ohms I believe or would I need to connect them in parallel? I think I can just connect them in a series, I just would like to verify that is Ok before I do anything.
    Thank you!
    fasfocus00's Avatar
    fasfocus00 is offline doITdaWHITEwayORdoITtwice
    Jun 2007
    New Orleans, LA
    5,618
    3 Post(s)
    459 Post(s)
    Re: 5 channel amp and 6 speakers plus sub?
    what car? are your 4x6s, 6.5s, and 6x9 all factory locations?
    Here is my feedback Thread: http://www.caraudio.com/forum/showth...ght=fasfocus00
    "If you ain't cheatin', You ain't trying"
  3. Thanks bbroge thanked for this post
  4. #3
    bbroge's Avatar
    Jun 2010
    Madison, WI
    Quote Originally Posted by fasfocus00 View Post
    These speakers are installed in a 2002 Chevy Blazer, all factory locations.
  5. #4
    joelp88's Avatar
    joelp88 is offline Junior Member
    Jun 2010
    Fairmont, WV
    Yes, in series you would have a 4 ohm load.
  6. Thanks bbroge thanked for this post
