Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: Subs cut out
    MXJMR's Avatar
    MXJMR is offline Senior VIP Member
    May 2003
    Naptown, IN, US of A
    212
    Subs cut out
    I installed my friends amp and two 10"s w/ an 8 gauge amp kit. He recently Bought two 15" flame q's and i told him hes gonna need to get a larger gauge power and ground, and a circuit breaker. He blew the fuse in no time and i put a new 60 amp fuse in (a 60 amp was in before) then got 4 gauge power and ground. Once he turns it up to about 16 it will stop hitting and you have to turn it down a notch and it will hit again we are going to put a circuit breaker in (atleast 140 amp maybe 200 amp) and i was wondering if this would fix the problem. If not what is the problem and how do i fix it.
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    Re: Subs cut out
    Before you keep on going up the amp rating of the circuit breaker, tell us what type of amp you're talking about.
    It might need like a 140A fuse, but it might not. It COULD very well be a connection problem.
    Only when you turn it down, you get power again. I suspect the amp might be going into protection (wrong ohmload)
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
    nosaj070's Avatar
    nosaj070 is offline CarAudio.com Veteran
    Feb 2003
    Chicago, IL
    32
    2,393
    Re: Subs cut out
    Gains may also be set incorrectly(too high)
    Alpine CDA-7995, A/D/S 3 Series Comps, ED 8A, SoundStream Reference 604, 98 Civic Sedan
    AIM: nosaj070
    MXJMR's Avatar
    May 2003
    212
    Re: Subs cut out
    140 amp fuse, never in my life have i seen a 140 amp aue fuse maybe anl but not aue or maxi.
    paikiah's Avatar
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    Re: Subs cut out
    Quote Originally Posted by MXJMR
    140 amp circuits breakers (not fuse, never seen them) flood the market here.
    i did mean circuit breakers, not fuses.. my bad.
    Team Caraudio
    Sony C90, 210 EQ
    RF 60.2 amp
    eD A15.22
    yz_gt69's Avatar
    yz_gt69 is offline Senior VIP Member
    Dec 2003
    canada
    33
    339
    Re: Subs cut out
    hey, i kinda got the same situation, i have 2 mtx 6000 12's (4 ohm subs) wired at 2ohms with a 2ohm stable kenwood 7201 (800W)
    at higher volumes it cuts, probably going into protection?? my grounds and connections are fine. so obviously w/e u can suggest would be cool
    I figure i won't play it till i get some feedback bein a rookie and all.
    thank ya
    tommyk90's Avatar
    tommyk90 is offline THE WHOLE THING!!!
    Oct 2002
    Chicago Heights, IL
    33
    16,641
    20
    1 Post(s)
    76 Post(s)
    Re: Subs cut out
    Quote Originally Posted by yz_gt69
    thank ya
    That amp is NOT 2 ohm BRIDGED stable. You either have to run each sub to its own channel, or wire the subs in series and bridge the amp. Either way you'll get the same amount of power to the subs. I suggest running one sub to each channel, thats the easier way to do it.
    Team Kicker (R.I.P.)
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
    2008 Bassrace 130-139.9 Regional and National Champion
    2006, 2007, 2009, 2010, 2012 and 2013 MECA Champion (S1, SR1, DB1, S2, S3, S4, S5)
    One DD 9510 powered by two Sundown SAZ-2500's
    Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
    Kicker wiring throughout.
    SPLNOMA's Avatar
    SPLNOMA is offline SQLer
    Oct 2003
    Wilmington N.C.
    32
    67
    Re: Subs cut out
    it could be the OHM problem being that ur amp is not 2ohm stable when bridged if that is the case if not i could be all sorts of things like a ground feedback (your sub xcrusioning to much throwing feedback through ur RCA`s if thats the case turn the gains down
    99 sonoma ext cab
    TEAM CARAUDIO.COM
    Panasonic HU !touch Screen!
    Eclipse 21000 in dash EQ
    SI MAG D2
    memphis1100d
    memphis 200.4
    Mb Quart 4x6 in Dash
    Mb Quart 6.5 comp set
    146db-lin X driver door open off windsheild
  9. #9
    yz_gt69's Avatar
    Dec 2003
    canada
    33
    339
    Re: Subs cut out
    hey guys
    thx for the reply guys,
    tommy: wont runnin each sub to its own channel lose power by not bridging?
    you guys should see the box I built for my 66 c-10 step side, i'll get a pic soon and post it, it's nothin too special but it fits mint and looks great.
    thx for the help
  10. #10
    tommyk90's Avatar
    Oct 2002
    Chicago Heights, IL
    33
    16,641
    20
    1 Post(s)
    76 Post(s)
    Re: Subs cut out
    hey guys
    thx for the help
    You will lose power, but your amp cannot handle a 2 ohm bridged load so it's pretty much your only option.
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
  11. #11
    B&R Innovation2's Avatar
    B&R Innovation2 is offline www.soundhertz.com
    Mar 2003
    Westchester NY
    1,019
    Re: Subs cut out
    Gains are set wrong IMO...turn them down and then turn it up
    I used to spend a lot of my free time here. It was fun I suppose. Still rocking the 9515 and Better Audio amp haha.
    How's incriminator stuff these days?
  12. #12
    yz_gt69's Avatar
    Dec 2003
    canada
    33
    339
    Re: Subs cut out
    B&R
    my gains are set at 100 for the lpf and 1 for the input sensitivty.
    if i rewire my subs to 4 ohms bridged wut would you suggest for those levels?
  13. #13
    tommyk90's Avatar
    Oct 2002
    Chicago Heights, IL
    33
    16,641
    20
    1 Post(s)
    76 Post(s)
    Re: Subs cut out
    B&R
    You can't wire your subs to a 4 ohm bridged load. You can either have a 2 ohm (parallel) load or an 8 ohm (series) load.
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
  14. #14
    yz_gt69's Avatar
    Dec 2003
    canada
    33
    339
    Re: Subs cut out
    tommy
    based on my system (in a previous post) do you think i'd be able to wire it to an 8 ohm series? if so, could u whip up a diagram for me?
    i realy appreciate all the help
  15. #15
    tommyk90's Avatar
    Oct 2002
    Chicago Heights, IL
    33
    16,641
    20
    1 Post(s)
    76 Post(s)
    Re: Subs cut out
    tommy
    Well, i dont have a diagram, but i can tell you what to do. It's pretty easy actually. Take the + from the bridged channel on the amp, run it to the first subs +, then run wire from the first subs - to the second subs +, then run wire from the second subs - to the - on the bridged channel on the amp.
    Here's a link to some pics.
    http://www.rockfordfosgate.com/rftech/wiringwizard/
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
  1. New plan..Treo..need help on these subs
    By 60_cent in forum Subwoofers
    Last Post: 04-20-2006, 03:15 PM
  2. 2 subs wanted, higher SPL than w7
    By maniackilla in forum General Discussion
    Last Post: 12-17-2003, 12:31 PM
  3. Newbie needs info on subs
    By arnjolt in forum Subwoofers
    Last Post: 10-03-2003, 05:44 PM
  4. subs for rockford amp
    By linkin in forum Subwoofers
    Last Post: 08-01-2003, 02:00 AM
