Results 1 to 3 of 3
Reload Thread: 2000 ford taurus help
    sdavis1465's Avatar
    sdavis1465 is offline Junior Member
    Dec 2003
    Bixby, OK
    Icon32 2000 ford taurus help
    I am wanting to use a couple of aftermarket amps with my factory head unit. I have to use factory because of the digital climate control. What I need to know since the tuner and antenna is located in the trunk is where is a good place to run my remote and constant from my eq? I had the remote going to the power antenna switched and it was grounded to a bolt on the front seat since the eq is right by the seat. The problem was it kept draining the battery with no constant hooked up. Where can I run me power wires to turn everything on. I'm no beginner but this is the first time working with this kind of setup.
    hoss's Avatar
    hoss is offline imma genius. so **** it!
    Sep 2003
    inside icetee, while he is inside seths sister
    34
    13,810
    Re: 2000 ford taurus help
    man, i am in the same boat with you with the digital controls... i cant believe n oone makes a kit for it, teh situation ***** donkey turd. i think i have found a way around it though... gonna be tricky though.
    sdavis1465's Avatar
    Dec 2003
    Bixby, OK
    To Update, I have everything hooked up but cant find a remote wire to connect to. If I take the remote wire from the amps and connect them to a battery wire they amps will work. Any suggestions??
  1. Install a head unit in a 91 Ford Taurus SHO
    By pieter3d in forum Wiring, Electrical and Installation Help
    Last Post: 01-18-2004, 02:14 AM
  2. 2000 Ford Taurus
    By sdavis1465 in forum General Discussion
    Last Post: 12-31-2003, 05:20 PM
  3. 2000 Malibu wiring help
    By 02Mazda626 in forum Wiring, Electrical and Installation Help
    Last Post: 12-08-2003, 08:07 PM
  4. Alpine radio to Ford Factory equalizer.
    By Cruise_Missile in forum Wiring, Electrical and Installation Help
    Last Post: 07-23-2003, 01:43 PM
