Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Reload Thread: amp shuts off at high bass hit
    eaglemn05's Avatar
    eaglemn05 is offline that one dude
    Dec 2003
    Tulia, Tx
    30
    44
    my amp shuts off when i turn my head unit up to like about 30 (max is 50) and when it hits a hard bass, my amp shuts off....it is a four channel amp, i had 2 subs, but i unplugged one(cause one alone sounds best) and i have that one bridged on the rear...because my HU has "rear" written on the output wires...what do i do?...i knwo it's not getting hot cause i don't run it for that long....
    i have it bridged RR+ and LF-
    should i bridge it Rf+ and Lr-?
    - Jason
    used '88 Ford Escort GT - $800
    white body with orange racing stripes - $0 (connections)
    custom made orange and white seats - $630
    2 6x9 X-plod speakers - $80
    2 5.25" X-plod speakers - $60
    2 10" X-plod P5 series subs - $57 each
    Jensen 600 watt amp(working on another) - $100
    JVC KD-LX111 El Kamleon HU- $200
    external MP3 player - $300
    2 10" orange neon tubes under dash - $50
    premade sub box- $80
    the joy of spending more money on the accesories inside your car than the car itself - priceless
    if i were to have a basketball team, i would name them "off in the woods" cause nobody beats "off in the woods"
    ditto985's Avatar
    ditto985 is offline Fiberglass king
    Dec 2003
    Denver, CO
    32
    70
    Re: amp shuts off at high bass hit
    sounds like a faulty amp to me, hopefully you have warranty
    Friends Don't Let Friends Buy MTX
    eaglemn05's Avatar
    Dec 2003
    Tulia, Tx
    30
    44
    got it at a pawn shop...no warranty
    - Jason
    eaglemn05's Avatar
    Dec 2003
    Tulia, Tx
    30
    44
    i haven't tried it since i hooked it to the rear, i had it hooked to the front, maybe that's waht the problem was...i will drive around and see
    - Jason
    ditto985's Avatar
    Dec 2003
    Denver, CO
    32
    70
    you can also try to change around which channels you bridge, sometimes it can just be something where one channel has gone bad
    eaglemn05's Avatar
    Dec 2003
    Tulia, Tx
    30
    44
    well it did the same thing, it cuts off
    but it gets worse the more i drive, it flickers on and off....could it be my battery, i have battery problems....sometimes i have to boost it off
    - Jason
    eaglemn05's Avatar
    Dec 2003
    Tulia, Tx
    30
    44
    what the heck do i do? it's pissing me off....i can't figure it out
    - Jason
    blushadow_db160's Avatar
    blushadow_db160 is offline Diamonds Are Forever
    Dec 2003
    Billings,MT
    31
    22
    hey if the jenson is the and make shure you are running at least 10 gauge power and ground with a 30 amp fuse. I had the same problem before. Your running your amp dry it's thristy feed it more.
  9. #9
    ditto985's Avatar
    Dec 2003
    Denver, CO
    32
    70
    if you want a new battery, go optima deep cycle, or if you want add a capaciter
  10. #10
    ditto985's Avatar
    Dec 2003
    Denver, CO
    32
    70
    Quote Originally Posted by shrinkydinx
    $50 for two neons?? too much..
    man are you even on the right forum no even mentioned neons
  11. #11
    Dec 2003
    Billings,MT
    31
    22
    when bridging a four channel amp you are supposed to bridge the rear to rear and front to front. Doing front to rear or rear to front with not give any more power just require more tuning. On most 4 ch. amps the rear channels have the lp xover (lp stands for Low pass) in turn means bass. so if i were you i would run both subs in parallel. Lowering the inpedence and increasing wattage. And hook them up to the bridged rear ch. just a little tip.
  12. #12
    Dec 2003
    Billings,MT
    31
    22
    hey shrinkydinx
  13. #13
    ditto985's Avatar
    Dec 2003
    Denver, CO
    32
    70
    oh i understand now. I guess my sisters aren't the only ones in my family who are blondI understand now, I guess my sisters aren't the only blonds in the family
  14. #14
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,449
    11 Post(s)
    ditto985 - OWNED by shrinkidinx
    -Mike L.
  15. #15
    eaglemn05's Avatar
    Dec 2003
    Tulia, Tx
    30
    44
    they were the only orange ones i could find....leave me alone ...lol
    if i ran them in a parelleelelelle whatever....wouldn't that fry my amp?...i have the wire that came with the amp kit....i dunno what gauge it is...the box says 4 gauge, i am a newbie at this ****, i dunno nothing about it....
    on my instructions for my subs it says "two 4-ohm speakers, wired in a parallel to a bridged two-channel amplifier will present a 2-ohm load to the amplifier. MOST TWO-CHANNEL AMPLIFIERS DO NOT SUPPORT 2-OHM MONO OPERATION! AMPLIFIER DAMAGE COULD RESULT!" and then it has a line through a smiley face lol
    so if i parallel them, wouldn't that mean it is pulling more watts from the battery, causing it to shut off even more frequent?
    - Jason
  1. Bass Songs
    By flyasspimp in forum General Discussion
    Last Post: 08-22-2005, 11:54 PM
  2. sub amp going into protection when low notes hit
    By B|2imstone in forum Amplifiers
    Last Post: 12-08-2003, 03:12 AM
  3. amp shuts off
    By androidsixseven in forum Wiring, Electrical and Installation Help
    Last Post: 11-01-2003, 12:42 AM
  4. What is a High Current Amp?
    By meanman101 in forum Amplifiers
    Last Post: 10-25-2003, 08:02 PM
  5. amp shuts off
    By KARLEON in forum Wiring, Electrical and Installation Help
    Last Post: 09-27-2003, 08:35 PM
