Results 1 to 7 of 7
Reload Thread: Newb Needs Help
    MkivSquared's Avatar
    MkivSquared is offline Junior Member
    Dec 2003
    Denver, Co
    40
    Newb Needs Help
    I am trying to install componants into a door that already had a seperate woofer and tweeter.
    How do I wire up the crossover?
    Do i just wire the wires from the woofer or do i twist both positives together and both negatives together?
    Thanks.
    sleepr's Avatar
    sleepr is offline Senior VIP Member
    Nov 2003
    Springfield, Mo
    43
    287
    Re: Newb Needs Help
    What brand and model # of componets?
    2004 Grand Prix GT-384 WHP, ??? ft/lb TRQ?
    The #2 highest horsepower 2004 Grand Prix in North America runs an Stock Cam, Stock Heads, Ported Manifolds, Corsa exhaust, Cartuning Upgraded Turbo Kit w/Intercooler, and Custom PCM.
    SLEEPR
    Dec 2003
    Denver, Co
    40
    Re: Newb Needs Help
    They are Phoenix Gold QX600. So, how do I wire them up?
    Are those any good? They were freebies from a friend of mine.
    93.5 Toyota Supra
    02 VW GTi
    And car payments to match.
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    Re: Newb Needs Help
    I can't seem to find the model on google.com.
    If the crossover has a separate woofer and tweeter output, then by all means, link the woofer to woofer, tweet to tweet. The input is where you amp's speaker output will go to.
    I also have a feeling that maybe you got yourself a COAXIAL, and not a comp. If this is so, then the comp SHOULD rightfully have its own crossover. If not...
    Well, be more specific please.
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
    Dec 2003
    Denver, Co
    40
    Re: Newb Needs Help
    No they are definitely comps. I have a seperate woofer, tweeter and a crossover.
    The factory stereo already has a sepereate woofer and tweeter too though.
    So would the factory amp already have a crossover?
    Thanks.
    93.5 Toyota Supra
    02 VW GTi
    Dec 2003
    Denver, Co
    40
    Re: Newb Needs Help
    Bump
    Common guys, i need to get these speakers in.
    93.5 Toyota Supra
    02 VW GTi
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Re: Newb Needs Help
    You need to get a wiring diagram for your car's system and find out how the factory wired the speakers in. If there's separate wires from the deck to the woofers and tweeters, you can assume the crossover is built into the amp and it's PROBABLY safe to just wire the new speakers in without any additional crossover.
    If the factory wiring puts the tweeter and woofer in parallel (one set of wires split to 2) then the factory crossover is probably built into the tweeter and you can't use the factory wiring.
    The safest and best way is to use the factory woofer wires as the input (amp terminals) on the component's crossover, then run new wires from there to the woofers and tweets.
    See if you can find wiring info for your stock system at www.installdr.com
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  1. im a newb to box building... help me out
    By rocktonic13 in forum Enclosure Design & Construction Help
    Last Post: 02-29-2004, 11:54 AM
  2. Newb quesiton about Kicker S12L54
    By stevieB in forum Subwoofers
    Last Post: 12-04-2003, 05:52 PM
  3. Almost complete newb
    By mirroredfire in forum General Discussion
    Last Post: 12-03-2003, 05:03 PM
  4. newb question, does sub need to be centered?
    By tony7 in forum Subwoofers
    Last Post: 11-06-2003, 08:59 AM
  5. newb needs help
    By n1k86 in forum Speakers
    Last Post: 10-12-2003, 08:03 AM
