Results 1 to 3 of 3
Reload Thread: 4 channel amp speaker wiring
    jdenny21's Avatar
    jdenny21 is offline Junior Member
    Dec 2003
    St. Louis, MO
    Hello all,
    I have a 2002 chevy tahoe and am installing a 4 channel amp. I will use the front 2 channels of the amp to drive the component speakers in the front door, and the coaxial speakers in the rear doors. I will brigde the rear two channels to drive an 8" audiobahn sub in a qlogic custom enclosure that fits inside the forward center console out of sight. I have wired a few amps before, but am somewhat confused on how to find the factory speaker wires where they come out of the doors, or identify them. I am mounting the amp under the rear seat, and would like to run the speaker wires directly to the speakers, but not sure how to get the wires into the doors. If anyone could help me with this issue, I would greatly appreciate it.
    Thanks for the help.
    John
    Diplexers's Avatar
    Diplexers is offline Logarithmic Robot
    Dec 2003
    Phoenix, AZ
    41
    2,433
    4 Post(s)
    Re: 4 channel amp speaker wiring
    This can be tricky. The only method I have found to run the speaker wires along the original route is good old fashioned elbow grease. Have to remove some panels and start feeding wires, its a tedious proccess but its satisfying in the end.
    Eclipse CD5000
    PPI... DEQ-230
    PPI... PC450 4 channel
    Eclipse DA7232 (2000 watts RMS)
    Focal PS130 Front
    Kicker RS6 6.5" comps
    Kicker R5c 5.25" midrange
    jdenny21's Avatar
    Dec 2003
    St. Louis, MO
    Back to top
  1. Wiring 4 speakers to a 2-channel amp...
    By Forty-Ouncer in forum Wiring, Electrical and Installation Help
    Last Post: 08-18-2004, 10:20 PM
  2. strangest wiring problem ever, PLEASE HELP!!! (thanks!)
    By dragonplayboy in forum Wiring, Electrical and Installation Help
    Last Post: 12-21-2003, 04:51 PM
  3. wiring a 2ch 1100W max eclipse amp
    By maestrogabriel in forum Wiring, Electrical and Installation Help
    Last Post: 12-19-2003, 08:31 PM
  4. Eclipse (or any 4 channel amp) Wiring/Setup Help
    By downsider in forum Amplifiers
    Last Post: 11-16-2003, 08:25 AM
  5. xtant amp and a good 4 channel
    By vod88 in forum Amplifiers
    Last Post: 09-15-2003, 11:08 AM
