Results 1 to 4 of 4
Reload Thread: Getting group 31 battery, now what!?
    mrjoeyjiffy's Avatar
    mrjoeyjiffy is offline Senior VIP Member
    Feb 2008
    Duuuuuuval
    180
    I should have my deka 9a31 in the next few days, but I'm not sure if I should.
    A.) Store it until i can afford the deka 9a34 for under the hood and throw an isolator between them
    or
    B.) Take my yellowtop out of the rear, put it under the hood and put this 9a31 in the back?
    also, new tires(so i dont hydroplane and die) or a nice new mechman alt?
    My current setup is a standard ac delco(i think) battery under the hood and a yellow top in the rear and my alternator rewound to 190 amps(but i think its not as much, i still get bad dimming). Also, my rear battery is grounded to the floor, should i reground it to the negative post of the battery under the hood?
    2001 Chevy Tahoe
    190a alternator
    Optima Yellow top under the hood Deka Group 31 yellow top in rear
    RD Audio Alpha Comp v2 components up front Tweeters replaced with Infinity Kappa Tweeters
    RD Audio Alpha Comp v2 components in rear
    Rockford Fosgate Punch P400-4
    2X Rd Audio 1750.1s
    Pioneer Avic-D3
    3X Jbl W12 Gti MkII's
    REFS: bizflawless, vitveet, Jando86, da box king
    StickyFingaz's Avatar
    StickyFingaz is offline Junior Member
    Dec 2009
    Vernon, BC
    24
    Re: Getting group 31 battery, now what!?
    I would do B) in the mean time while you await the 34. Leave the chassis ground but add a negative run of 0 gauge to the front batt.
    Feb 2008
    Duuuuuuval
    180
    ok, But if i run an isolator i wouldnt want to connect those 2 negatives of the different batteries would i?
    2001 Chevy Tahoe
    190a alternator
    2X Rd Audio 1750.1s
    Pioneer Avic-D3
    smoka's Avatar
    smoka is offline Drink beer save water
    Jan 2009
    Chicago
    664
    10 Post(s)
    Buy a 2nd 9a31 for the back, then get rid of the front batt. Have 0ga runs from your alt to your batts for power/ground.
    The 34 + the cost of an isolator is probably near the same price, not to mention the small voltage drop you get from using isolators.
    If you have 2 of the same batt (close to the same age as possible), then theres no need for an isolator.
