i have purchased a kicker solobaric 10'L7 sub. is there a difference in ohm ratings... 4 ohms and 2 ohms.... which is better .... is there a difference in performance.... using a pheonix gold octane r 4.0:2 bridged at 4 ohms at 400 watts
Ohms makes no difference in performance, it just allows you to have different wiring options. What impedence is the woofer that you bought?
the lower the impedence (ohms) the more power you will get
ohms are a measurement of resistance, the lower the ohms the lower the resistance
lower resistance means more room for distortion
Uh... no. Lower ohms just means that the subs will draw more power from a given amp.Originally Posted by thumpin90gts
You need to balance the total impedance (ohms) of the subs to your amp. From what you said, the amp wants 4 ohms to run bridged. So get either a 4 ohm sub or a dual 2 ohm and wire the coils in series for 4 ohms.
dave
1999 Buick Park Ave Ultra
Head Unit: JVC KWHDR720
EQ: Audiocontrol EQL
Front Stage: Hybrid Audio Technologies Imagine 5.25
Sub Stage: In process (will be Boston G310)
Amp: Boston Acoustics GTA-704 4 Ch
Rear Fill: Boston SE953 6X9's
Try looking around on the www for topics related to Ohm's Law to better understand how your stereo works. This will lead, believe it or not, to a better sounding system as well as an easier installation.
Bookmarks
