Results 1 to 3 of 3
Reload Thread: JL 10W6 Problems
    Shawnm's Avatar
    Shawnm is offline Junior Member
    Dec 2003
    Seattle
    JL 10W6 Problems
    I have a set of 10W6's. There is somethign wrong with them - when I push them they don't have any movement. They won't move up and down like they are supposed to, like they are just stuck in one spot. I have a feeling that means they are toasted, though I was wondering if there is a way to fix them? Also, what could of caused that??
    Thanks!
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    Re: JL 10W6 Problems
    Take them to a JL dealer to send them to be reconed. $90 per sub. Cooked coil usually caused by running a clipped signal through the sub.
    Shawnm's Avatar
    Dec 2003
    Seattle
    Thanks for the info -
    Do you know if there's a way to replace the coil yourself.... 90 bucks seems kinda steep, almost worth while buying new subs. A coil is pretty simple, just like the name sounds - a coil of copper wires. Any tuts on the net you've seen to do this?
  1. kenwood amp problems
    By REAA in forum Wiring, Electrical and Installation Help
    Last Post: 11-28-2003, 12:57 PM
  2. Alpine 9815.. serious problems
    By Zylo in forum General Discussion
    Last Post: 11-20-2003, 09:43 PM
  3. Problems with Dims and Skips
    By Mash Jetta TDI in forum Wiring, Electrical and Installation Help
    Last Post: 08-04-2003, 05:25 PM
