Results 1 to 5 of 5
Reload Thread: Mb Quart RSB 328 - 3-way components
    dutchinc's Avatar
    dutchinc is offline Junior Member
    Dec 2003
    Charlottetown, PEI, Canada
    Hey I have aquired a set of these and they came with Musicomp MCX 328 crossovers.
    Now my question is, these crossovers are bi-wire compatible.
    Now does this mean if I wire them that way, that i'd be running at 2 ohm?
    This is important as if it is 2 ohm, I'd be running 120 rms to each , instead of 60.
    Also, has anyone ever heard this set up before?
    thx
    mtech2's Avatar
    mtech2 is offline Member
    Dec 2003
    chicago
    98
    Re: Mb Quart RSB 328 - 3-way components
    Bi wire set-ups are a waste of money and cannot be audibly detected in anything less than the absolute best money can afford. (and even then I doubt it is noticeable) So unless that's what your running don't bother, just use a high quality, higher gauge speaker wire and you will be fine. No, it would not effect impedence.
    darb215's Avatar
    darb215 is offline Junior Member
    Nov 2003
    Az
    Quote Originally Posted by mtech2
    Higher guage wire raises attenuation...use 16g
    Mar 2003
    Northeast
    2,408
    8 Post(s)
    I though bi wire meant that you could power the woofer and tweeter of a coaxial speaker seperatly oh wait maybe thats bi-amp well if that is the case i m sure that would make a difference in the sound since you would be feeding each driver twice as much power...
    Refs: Diyma.com, Caco.com
    mtech2's Avatar
    Dec 2003
    chicago
    98
    My bad....meant larger wire ; smaller gauge.
  1. mb quart
    By awestone05 in forum General Discussion
    Last Post: 01-19-2004, 10:42 AM
  2. MB Quart DSD 213's with Musicomp C/O's
    By 80_Cutlass_mn in forum Speakers
    Last Post: 12-01-2003, 01:04 AM
  3. Crystal CSC 5 1/4 components w/ Silk Tweeters
    By Bavarian3 in forum Subwoofer and Speaker Reviews
    Last Post: 11-17-2003, 09:07 PM
