Results 1 to 3 of 3
Reload Thread: Car Amp Not turning on
    echo5625's Avatar
    echo5625 is offline Junior Member
    Dec 2003
    San Antonio
    Icon32 Car Amp Not turning on
    I have just recently installed an amp in my car. its a 400 watt max amp. I hooked it up to all the right specifications, but when i try to turn it on it turns on for split seconds, then turns off. could my power wire, not be thick enough? i know my amp works, becasue i had a friend test it in his car. Does it really matter where you ground the car and if not groundly properly could this cause it not to work? if anyone can help me figure out the problem it would be great. Thanks, Robert
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    37
    8,477
    32
    Re: Car Amp Not turning on
    Yes, the ground is very important. Make sure you're grounding to the chassis, the surface is sanded down to bare metal, and the connection is secure.
    "The world is full of people who want nothing short of perfect,
    but settle for less, blinded by their quest for purpose."
    - Slug
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    If it turns on for a second and shuts off I would suspect that the speaker wires are shorted. If you'r running subwoofers from it you could have too much load (low ohms) for the amp to handle.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  1. amp goes into protection when car starts
    By BulldogSr04 in forum Wiring, Electrical and Installation Help
    Last Post: 12-08-2003, 08:13 PM
  2. amp turning off?
    By Killa sin in forum Amplifiers
    Last Post: 11-26-2003, 09:57 AM
  3. amp turning off?
    Last Post: 11-10-2003, 11:33 PM
  4. How can I run a car amp off a 120v circuit?
    By Hambone in forum General Discussion
    Last Post: 10-23-2003, 07:43 PM
  5. hooking a car amp up in my dorm room
    By Qball in forum General Discussion
    Last Post: 09-09-2003, 10:11 PM
