Results 1 to 4 of 4
Reload Thread: Speakers cutting out, please help
    chenal73's Avatar
    chenal73 is offline Junior Member
    Dec 2003
    LR,AR
    Right front speakers are cutting out or producing static, on an intermittent basis, not all the time. Seems to happens when I make a left turn.
    Isolated each speaker at the amp, the speaker that is hooked up still has the problem. So I don't think I have a speaker wire grounding out, or just loose. Wiring to the problem speakers looks good.
    I have a PPI PCX440 powering the speakers, it's about two years old. I have checked all wiring and connections, seem ok. All other speakers powered by the amp work fine all the time.
    Maybe something has worked loose in the amp that feeds the signal to the right front channel?
    What else to check?
    Thanks for any help you can offer.
    chenal73's Avatar
    Dec 2003
    LR,AR
    Re: Speakers cutting out, please help
    No ideas?
    What about the interconnects maybe?
    chenal73's Avatar
    Dec 2003
    LR,AR
    yep, it was a loose wire inside the head of the interconnect, broke loose from solder point.
    chenal73's Avatar
    Dec 2003
    LR,AR
    for supposedly high quality interconnects, these wires were about 20 or 22 gauge. makes you wonder about the debate concerning the appropriate size of speaker wires.
  1. unbalanced speakers, advice?
    By Sharp_Shoota in forum General Discussion
    Last Post: 02-23-2004, 02:40 AM
  2. Replies: 7
    Last Post: 12-11-2003, 10:20 AM
  3. New speakers distorting.
    By slothy in forum Speakers
    Last Post: 12-05-2003, 03:25 PM
  4. cheap speakers ? (500watt amp)
    By Stingraynut in forum Speakers
    Last Post: 10-18-2003, 09:34 AM
  5. What the hell is wrong with my speakers?
    By goofballer in forum Speakers
    Last Post: 07-31-2003, 08:27 PM
