Results 1 to 7 of 7
Reload Thread: Install advice needed
    fas's Avatar
    fas
    fas is offline Junior Member
    Dec 2003
    MA
    I have Infinity Reference components in the front, stock 5 1/4 in rear with a small powered sub in the rear for fill, a 4 channel MTX amp and a Kenwwod Excelon installed in a SUV. I just had the Excelon installed to replace a Pioneer.
    My question is what speakers should I run off the amp?
    Sound was great until the install of the Excelon. I'm not sure if the installer changed the setup. Now, all the bass in coming from the small sub and the Infinity's up front sound like cardboard speakers and hurt my ears. I used to get some bass from the front along with great highs and mids. I'm guessing that the fronts were powered off the amp and the rears were off the HU before the change. I'm not sure if the difference is between the Pioneer and the Kenwood or the way the new one was set up.
    My goal is to have good clean sound with a little added bass again.
    Any help appreicated.
    tobz's Avatar
    tobz is offline Independant Thinker
    Nov 2003
    MN
    35
    507
    Re: Install advice needed
    You will probably need to adjust the settings on the Excelon deck. There are going to be crossover settings that will allow you to add bass and remove some of the treble. Play with those settings and you should be fine.
    fas's Avatar
    fas
    Dec 2003
    MA
    I've been adjusting the crossover and all other settings for a couple of days, nothing helps. It seems like there isn't any range in the adjustments.
    mattj's Avatar
    mattj is offline Resonant Engineering
    Aug 2002
    Wisconsin
    34
    6,293
    Read the instruction manual all the way through. That will help a lot.
    (SUMMER)
    2001 Ford Mustang GT Premium
    Mach460
    Alpine CDA-9835
    KnuKonceptz Wiring
    fas's Avatar
    fas
    Dec 2003
    MA
    Read the instruction manual again, still sounds like crap. While playing with the settings I noticed that if I fade all the way to the rear the sound dies completely. And, I found the wiring harness that was used for the Pioneer under my front seat. Could they have used the wrong harness?
    The difference between the two setups is like night and day. Both HU are new, Excelon X569 and Pioneer DEH 5500. I'm bringing it back to the shop next week and any help with this is much appreicated.
    desi_daru's Avatar
    desi_daru is offline CarAudio.com Elite
    Nov 2003
    BC, Canada
    543
    mess around with the gain settings and bass bost and all that ish on the amp, also how about the settings on the x-over for ur comps
    u could try running sub/fronts off amp so itll b bridge to 2 channels and have the stock rears running off deck power, but i dunno what amp/sub you got so i wouldnt suggest it just yet
    Car - 04' Honda Civic Si, silver
    Deck - Clarion ProAudio DXZ835MP
    Fronts - Alpine Type-R SPR-136A (5.25" comps w/ 1" tweet)
    Speaker Amp - MTX Thunder404
    Sub - 1x Rockford Fosgate RFP3412 ported box
    Sub Amp - Rockford Fosgate Punch 150S
    Wiring - power/ground 4guage, speaker 16guage
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    65
    3,498
    2 Post(s)
    399 Post(s)
    Ask whoever did the last install what he fukked with. Check the hipass frequency and gain settings on the amp.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  1. Pro installers needed!
    By boomsta in forum Enclosure Design & Construction Help
    Last Post: 11-02-2003, 04:49 PM
  2. Advice needed
    By Ilovemytunes in forum General Discussion
    Last Post: 09-23-2003, 02:01 PM
  3. Need advice and recommendations for new install please
    By MrJollie in forum General Discussion
    Last Post: 08-28-2003, 09:19 AM
  4. Need advice and recommendations for new install please
    By MrJollie in forum Wiring, Electrical and Installation Help
    Last Post: 08-28-2003, 09:18 AM
  5. advice needed
    By bijama in forum General Discussion
    Last Post: 08-13-2003, 04:27 PM
