Results 1 to 5 of 5
Reload Thread: Do I need to reverse the polarity if I want to flip/downfire my subwoofers
    AndrewOrwig's Avatar
    AndrewOrwig is offline Junior Member
    Dec 2003
    Madison, IN
    26
    I am still kinda new at this wiring thing, but i have the basics down, but i was wanting to fire my subwoofers into the box, or downfiring i believe is what it is called, and i wanted to know if i need to reverse the polarity on the voicecoils, or how i would wire them up to avoid damage to the speakers, if someone could jus explain the basic outline of this or give a good place to find this info i would be very much appreciative....thanks
    Andrew
    tobz's Avatar
    tobz is offline Independant Thinker
    Nov 2003
    MN
    31
    507
    Re: Do I need to reverse the polarity if I want to flip/downfire my subwoofers
    search for "invert"
    alove_85's Avatar
    alove_85 is offline Love is Life
    Jan 2003
    In Your Sister
    27
    3,016
    just reverse + and -
    Dec 2003
    Madison, IN
    26
    Thanks for the assistance, now i wont be worried when i go to turn them on
    Grimolfr's Avatar
    Grimolfr is offline Junior Member
    Nov 2003
    Atlanta, GA
    42
    Just a note: What you're talking about isn't down-firing, it's inverting.
    A down-firing sub is any sub that faces down, towards the floorboard. Regardless of whether it's firing into or out of the enclosure.
    An inverted sub is one that faces into the enclosure instead of facing out of the enclosure.
    Note that it is possible to have a down-firing sub that is also an inverted sub. It's also possible to have a down-firing sub that is not inverted, or an inverted sub that is not down-firing. The two terms are not directly related.
    But, to answer the question you would have asked had you known this already, if you're mounting a single sub inverted, it's probably better to invert the power also, which means switch the polarity.
    Grim
  1. Clarion subwoofers.
    By davey2020 in forum General Discussion
    Last Post: 12-05-2003, 09:18 PM
  2. kove audio subwoofers
    By david01_69 in forum Subwoofers
    Last Post: 11-11-2003, 08:27 PM
