Results 1 to 5 of 5
Reload Thread: why remove negative terminal?
    Dream01x's Avatar
    Dream01x is offline Junior Member
    Dec 2003
    Boston, MA
    when your supposed to do any electrical work, they always say to remove the negative terminal. can anyone explain why?? sorry i don't know much about this, I just recently fried my HU ( being stupid, not removing the terminals...). but yea, why remove the negatives? as opposed to the positives???
    thx
    desi_daru's Avatar
    desi_daru is offline CarAudio.com Elite
    Nov 2003
    BC, Canada
    543
    Re: why remove negative terminal?
    doesnt matter, removing one is good enuf, or just rip out the fuse, or do wat i do dont let them touch, heh i had lil spark incident amp was grounded, and power wire from other amp touched the heatsink and nice spark came out of it, lol no blown fuses so i dont care
    Grimolfr's Avatar
    Grimolfr is offline Junior Member
    Nov 2003
    Atlanta, GA
    47
    When disconnecting a battery completely, the appropriate method is to disconnect negative, then disconnect positive. To reconnect, you should connect positive, then negative. This is for safety reasons to reduce the risk of spark while disconnecting and reconnecting the cables, which could cause the battery to explode.
    In order to disconnect the positive cable properly for safety reasons, you should disconnect the negative cable first, anyway. It's simpler just to remove the negative cable to disrupt the power flow than it would be to remove the negative, then the positive, so it's generally accepted practice to just remove the negative cable.
    Grim
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Remove the battery GROUND wire first. In most cars that's the negative side (some British cars are positive ground).
    The reason is if you accidentally touch your wrench or ratchet to ground while removing the terminal, you'd get major sparks.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    nosaj070's Avatar
    nosaj070 is offline CarAudio.com Veteran
    Feb 2003
    Chicago, IL
    32
    2,393
    removing the ground(negative) it breaks the circuit so nothing will power on. just like if you were to unhook the ground from your amplifier, it would not turn on. and like everyone else said, saves you from electricuiting yourself/blowing fuses/ frying amps
    Alpine CDA-7995, A/D/S 3 Series Comps, ED 8A, SoundStream Reference 604, 98 Civic Sedan
    AIM: nosaj070
  1. Negative Battery Terminal Connection
    By TCC in forum Wiring, Electrical and Installation Help
    Last Post: 01-13-2004, 04:15 AM
  2. installing myself, i need some help
    By DbRufus1234 in forum Wiring, Electrical and Installation Help
    Last Post: 11-10-2003, 10:10 PM
  3. How to wire subs to subwoofer terminal?
    By 318iSPOLKMoMo in forum Wiring, Electrical and Installation Help
    Last Post: 08-17-2003, 11:05 PM
