Results 1 to 2 of 2
Reload Thread: 2000 Malibu wiring help
    02Mazda626's Avatar
    02Mazda626 is offline Junior Member
    Nov 2003
    New Orleans
    Ok my g/f has a 2000 Malibu and the engine compartment is so crowed that i have no clue where i could route the 4 awg wire to the trunk. Plz if anyone has done an install on a 2000 Malibu shed some light on where you fed the wire through and how easy/hard it was. I can do pretty much anything necessary to get it done, its just getting the wire through.
    skeetskurt's Avatar
    skeetskurt is offline Turn it up
    Jan 2003
    Grand Rapids, MI
    36
    90
    Re: 2000 Malibu wiring help
    The battery is on the drivers side, so underneath the dash is a grommet. Abig grommet through the firewall. Stick a blunt object in the grommet to open it up a bit. It is easy to do if you feed it straight. Look with a flashlight to the approximate spot and you will be able to see it. The fuse holder is in the way so either remove the lid or use a pair of long needlenose pliers to grab it up. By the way, you have to take off the black cover under the dash to see it, but it is right there.
  1. My first wiring gig, could use some help (diagram attached)
    By mschmidt10k in forum Wiring, Electrical and Installation Help
    Last Post: 11-13-2003, 01:37 PM
  2. Wiring Harness
    By MemphisSoul4U in forum Wiring, Electrical and Installation Help
    Last Post: 09-28-2003, 09:04 AM
  3. Help wiring
    By Bones33 in forum Wiring, Electrical and Installation Help
    Last Post: 09-06-2003, 01:25 AM
  4. !¿!¿!¿Total wiring help!¿!¿!¿
    By unard in forum Wiring, Electrical and Installation Help
    Last Post: 08-07-2003, 02:49 PM
  5. vw monsoon wiring harness?
    By triphop in forum General Discussion
    Last Post: 07-30-2003, 05:10 PM
