Results 1 to 2 of 2
Reload Thread: Need some advice on my Diamond Audio System
    ranger4416's Avatar
    ranger4416 is offline Junior Member
    Oct 2009
    St. Louis
    I have two Diamond M6 10 D4's and a Diamond D5 1200.1 Amp.....Im not exactly sure how to run the speakers wires from the amp to the subs. I was thinking that wiring each seperate sub in parrell and then wiring them both into parrell to the amp would be the best way...but i was told thats not the best way, and I'm just wondering what would be the best?
    acold7dusta's Avatar
    acold7dusta is offline y they stealin my bucket?
    May 2006
    buffalo, NY
    1,940
    Re: Need some advice on my Diamond Audio System
    if they're in one box, just daisychain all the (+) together and run them to your amp's (+) terminal, same with the (-) to the amp's (-) terminal
    01 Acura CL
    Eclipse CD3200
    Rainbow SLC 265 Active
    Sundown: SAX-50.4D
    ..............SAE-1000D
    Diamond D6 10" d2 sub
    ...........-.80 cu. ft FG sealed
