Results 1 to 9 of 9
Reload Thread: Electrical Issue (Blowing Distro Fuses, now Amp)
    NJTStang11's Avatar
    NJTStang11 is offline CarAudio.com Elite
    Dec 2004
    Chicago, IL
    32
    1,875
    43 Post(s)
    Well the issue started about a week ago. Here is equipment.
    Soundstream Pic 1700 ([email protected])
    15" Fi BL
    0 Gauge Wire (300a Fuse under hood)
    I originally had it wired to a distro block in hatch with small AGU fuses.
    I blew one fuse. Switched to other output/fuse and blew that one about 3hrs of driving later.
    After checking the fuses, they seemed to be too small for application.
    I wired the 0ga directly to the amp. Big mistake.
    About another 3-4 hours later of driving POOF amp goes up in smoke.
    I dont wanna replace it and blow another amp.
    What am I looking at here? Voltage drop?
    Electrical is all stock, but I've never really had problems before.
    Add another battery? Do Big 3?
    Subwoofers: 12" Soundsplinter RL-p
    Amp: Hertz EP1D
    Enclosure: 2 Cubes @ 32hz
    Refs: dropped_mazda, muffinman944, KCha, pioneerpimp, Looney_Tune, Ion SQL, IamMurph, stevexyz, dsmw, waccord99, snb778s
    94'BLKBRD's Avatar
    94'BLKBRD is offline Member
    Aug 2008
    So Cal
    134
    Re: Electrical Issue (Blowing Distro Fuses, now Amp)
    Do the Big 3 before you add another battery.
    NJTStang11's Avatar
    Dec 2004
    Chicago, IL
    32
    1,875
    43 Post(s)
    Quote Originally Posted by 94'BLKBRD View Post
    I dont wanna do Big 3 then blow another amp.
    Amp: Hertz EP1D
    tylork92's Avatar
    tylork92 is offline CarAudio.com Veteran
    Nov 2008
    North Carolina
    2,334
    28 Post(s)
    sounds like you got some MAJOR voltage drop and/or clipping the HELLZ outta your amp and frying it. The Big 3 should fix your problems...for 1700 watts rms your right on the edge of going to need a 2nd batt or Big 3 will fix all your probs. just do the Big 3 and watch your voltage on your new amp and SLOWLY turn it up and see if its fixed.
    [/SIGPIC][/SIGPIC]
    93 Ford Ranger
    full fiberglass panels and a-pillars
    XS d6500/ Mechman 260A
    2 SA15s
    Sundown 1500dv1
    Toolmaker plexi, dual inputs, distro blocks.
    Jul 2006
    Georgia
    12,847
    1 Post(s)
    1170 Post(s)
    What was your gain set at?
    What ohm is your BL?
    REFS:
    Squeak9798, Kumbos310w6, BigBangTheory, Jmanpc, MillzThaYungin, WLDock, -Leister-, ThomasG, J31Rob (and a few more I have forgotten)
    Quote Originally Posted by BassAndBeer View Post
    sorry man but ford will always be a ford. ford is the sony xplod of cars and trucks. you had bad experiences with chevy because your a ford guy. its what seperates the men from the boys. friend billy use to drive a ford. he drives a chevy now. they call him billy no more. hes known as bill now..
    NJTStang11's Avatar
    Dec 2004
    Chicago, IL
    32
    1,875
    43 Post(s)
    It wasn't a gain issue. Both that and the bass boost were set properly. Not to mention they were set twice on different subs and same issue occured (popped one fuse on 2 10" r's and other and amp on BL).
    BL is 2ohm wired to 1ohm.
    Amp: Hertz EP1D
    dbeez's Avatar
    dbeez is offline CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    9,436
    1 Post(s)
    915 Post(s)
    wait bass boost should be turned all the way to the left aka off never use it..And 1700rms on stock electrical..battery is probably about dead and alt is more than likely huffing now also you need at least one good batt and big three done asap before another amp goes in..Also never do that again always use a fuse if you didnt have one big enough should have bought a bigger one to be safe..
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps 2 Sax125.2 front stage crossfire [email protected]
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters 2 sets cdt m6+ mids 2 sets cdt tw25 tweets
    Subs 2-18" nightshade v2's d2
    System DetailsDaily driver.
    KINGDELL91's Avatar
    KINGDELL91 is offline KING OF KINGS
    Jul 2007
    Detroit, MI
    2,510
    1 Post(s)
    33 Post(s)
    Quote Originally Posted by dbeez View Post
    X2 Get a quality Batt up front yellow top will do fine, and get that Big 3 done and properly fuse everything. Might as well go with a 300 ANL for your BIG 3 and your power lines, and Make sure you have good clean Grounds!!!
    CA REFS: themommyvan DECADO2, PATH2SPL, NEVERENUFFBASS, xhilr8n, jdc753, Racerx250, Zxcvtypo, hc3_cuz, wong05tsx, JK_AUDIO, Supergumby5000, Ken448,mojobass, craigzter, GMOORE, MitchZ, dumple, djman37,Thewes,Team MAF, Dragnix, and others
    ROE REFS: Stoker_41, xhilr8n, blackdragonx118
    Feed back Thread as a buyer trader:http://www.caraudio.com/forum/showth...ght=KINGDELL91
    Feed back Thread Seller:http://www.caraudio.com/forum/showth...20#post3761820
    BUILD LOG http://www.caraudio.com/forum/showthread.php?t=303112
    Quote Originally Posted by bones22 View Post
    this thread should get a lot of attention over the title.
    compared to the jackhammer that thing should be called a tack hammer
  9. #9
    Jeremy M's Avatar
    Jeremy M is offline CarAudio.com Elite
    Oct 2007
    Moxee, Wa
    1,979
    3 Post(s)
    what brand 1/0g are u using?
    06' Acura MDX
    Pioneer F90bt
    JL Audio XR 653csi
    Alpine PDX 150.2
    JL Audio 13TW5
    Alpine PDX 1000.1
    2010 Mazdaspeed3
    Alpine CDA-9887 (w/ imprint)
    2 sets of ID OEM 6.5
    2 sets of ID XS-28
    PG Xenon x200.4
    1 Atomic 5000.1
    2 RD Alpha D2 15's
    Tons of deadner and wire!
