Results 1 to 10 of 10
Reload Thread: Help with my brake light not working
    TheJuggla1's Avatar
    TheJuggla1 is offline Senior VIP Member
    Apr 2009
    Surrey BC
    248
    I dunno I went to add these LEDs tail lights and I wired my left one in fine, it works properly. I went to wire my right side THE SAME WAY and when I went to check the brakes my right one doesn't work, the LEDs don't come on, but the left side works fine.
    The weird thing is the turn signal works fine however the brakes and the turn signal use THE SAME WIRE(I dunno if it is like this for all vehicles, but that is how it is on mine) so I am so stumped, I checked the fuse box, tried disconnecting the LEDs, switching the stock bulb(Check it with like 3 different NEW bulbs.) and no luck, can anyone help me out here?
    DSMW's Avatar
    DSMW is offline CarAudio.com Elite
    Dec 2007
    MN
    730
    Re: Help with my brake light not working
    haha mine dont work either after i installed my door pods. i took the loss and hope everyone rear ends me for isnurance money
    TheJuggla1's Avatar
    Apr 2009
    Surrey BC
    248
    Quote Originally Posted by DSMW View Post
    Don't think it works like that...
    DB-Audio's Avatar
    DB-Audio is offline Syko DJ music producer
    Mar 2009
    Newtown, CT
    2,654
    96 Post(s)
    if the left one is working you could either wire the right one the same way or run a wire from the right one to the left one
    2001 Honda Civic EX
    power acoustik 8" over sized touch screen
    doors Stock
    1- Atmos Audio 18
    1- Audiopipe 1000d mini @2 ohms
    Electrical stock for now
    http://www.youtube.com/watch?v=Cl_ardHXEkg"]My old System
    http://www.myspace.com/sykodjthereal"]If you Need Beats click this
    http://www.carstereoforum.net"]http://www.carstereoforum.net
    TheJuggla1's Avatar
    Apr 2009
    Surrey BC
    248
    Quote Originally Posted by DB-Audio View Post
    Umm no they use the same wire as the turn signal, I guess that COULD work, but when I go to left signal both signals would come on.
    DSMW's Avatar
    Dec 2007
    MN
    730
    no one has rear ended me in two months. and my brakes dont work but turn signal and such do still. and reverse lights.
    BushJ311's Avatar
    BushJ311 is offline CarAudio.com Veteran
    Feb 2008
    NW, PA
    7,443
    15 Post(s)
    So you have no brakes?
    fbi90909's Avatar
    fbi90909 is offline Panty Thief
    Jun 2006
    Key West, FL
    35
    7,768
    4 Post(s)
    swap them back to stock and see if the issue persist. if the stock does then you have a bad led tail light that may have a main connection wire loose or you didn't connect it properly.
    if the stock doesn't light up then you you may have a short somewhere. check your fuses.
    i will not put **** or outside links in my signature again. if i do i will be banned. all hail the moderators.
  9. #9
    TheJuggla1's Avatar
    Apr 2009
    Surrey BC
    248
    I don't give a **** about getting rear ended, it usually is their fault, I don't want a ticket and not being able to fix this.
  10. #10
    TheJuggla1's Avatar
    Apr 2009
    Surrey BC
    248
    Quote Originally Posted by fbi90909 View Post
    Sorry but you didn't read my post at all. I disconnect my LEDs, checked my fuses and tried multiple bulbs. And there is no switching back to stock, it is stock, the LEDs are basically a clear replacement Lens that goes over the stock bulbs.
